Datasheet LTM2886 (Analog Devices) - 6
DescriptionSPI/Digital or I2C μModule Isolator with Fixed ±5V and Adjustable 5V Regulated Power
Pages / Page38 / 6 — SWITCHING CHARACTERISTICS. The. denotes the specifications which apply …
SWITCHING CHARACTERISTICS. The. denotes the specifications which apply over the specified operating
SWITCHING CHARACTERISTICS The denotes the specifications which apply over the specified operating
LTM2886
denotes the specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25°C. LTM2886-3 VCC = 3.3V, LTM2886-5 VCC = 5V, VL = 3.3V, and GND = GND2 = 0V, ON = VL unless otherwise noted. Specifications apply to all options unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Logic
Maximum Data Rate DI1 → O1, Ix → DOx, CL = 15pF (Note 3) l 10 MHz tPHL, tPLH Propagation Delay CL = 15pF (Figure 1) l 35 60 100 ns tR Rise Time CL = 15pF (Figure 1) l 3 12.5 ns LTM2886-I, DO2, CL = 15pF (Figure 1) l 20 35 ns tF Fall Time CL = 15pF (Figure 1) l 3 12.5 ns LTM2886-I, DO2, CL = 15pF (Figure 1) l 20 35 ns
SPI
Maximum Data Rate Bidirectional Communication (Note 3) l 4 MHz Unidirectional Communication (Note 3) l 8 MHz tPHL, tPLH Propagation Delay CL = 15pF (Figure 1) l 35 60 100 ns tPWU Output Pulse Width Uncertainty SDO, SDI2, CS2 (Note 2) ±50 ns tR Rise Time CL = 15pF (Figure 1) l 3 12.5 ns tF Fall Time CL = 15pF (Figure 1) l 3 12.5 ns tPZH, tPZL Output Enable Time SDOE = ↓, RL = 1kΩ, CL = 15pF (Figure 2) l 50 ns tPHZ, tPLZ Output Disable Time SDOE = ↑, RL = 1kΩ, CL = 15pF (Figure 2) l 50 ns
I2C
Maximum Data Rate (Note 3) l 400 kHz tPHL, tPLH Propagation Delay SCL → SCL2, CL = 15pF (Figure 1) l 150 225 ns SDA → SDA2, RL = Open, CL = 15pF (Figure 3) l 150 250 ns SDA2 → SDA, RL = 1.1kΩ, CL = 15pF (Figure 3) l 300 500 ns tPWU Output Pulse Width Uncertainty SDA, SDA2 (Note 2) ±50 ns tHD;DAT Data Hold Time (Note 2) 600 ns tR Rise Time SDA2, CL = 200pF (Figure 3) l 40 300 ns SDA, RL = 1.1kΩ CL = 200pF (Figure 3) l 40 250 ns SCL2, CL = 200pF (Figure 1) l 250 ns tF Fall Time SDA2, CL = 200pF (Figure 3) l 40 250 ns SDA, RL = 1.1kΩ CL = 200pF (Figure 3) l 40 250 ns SCL2, CL = 200pF (Figure 1) l 250 ns tSP Pulse Width of Spikes Suppressed l 0 50 ns by Input Filter
Power Supply
Power-Up Time ON = ↑ to VCC2 (Min) l 0.6 5 ms ON = ↑ to V+ (Min) l 0.6 5 ms ON = ↑ to V– (Min) l 0.6 5 ms 2886fb 6 For more information www.linear.com/LTM2886 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Product Selection Guide Order Information Electrical Characteristics Switching Characteristics Isolation Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Test Circuits Applications Information Typical Applications Package Description Typical Application Related Parts
