Datasheet AD4112 (Analog Devices)
DescriptionSingle Supply, 24-Bit, Sigma-Delta ADC with ±10 V and 0 mA to 20 mA Inputs
Pages / Page58 / 1 — Low Power, 24-Bit, Sigma-Delta ADC. with ±10 V and 0 mA to 20 mA Inputs. …
RevisionA
File Format / SizePDF / 666 Kb
Low Power, 24-Bit, Sigma-Delta ADC. with ±10 V and 0 mA to 20 mA Inputs. Data Sheet. AD4112. FEATURES. GENERAL DESCRIPTION
Datasheet AD4112 Analog Devices, Revision: A
Low Power, 24-Bit, Sigma-Delta ADC with ±10 V and 0 mA to 20 mA Inputs Data Sheet AD4112 FEATURES GENERAL DESCRIPTION 24-bit ADC with integrated analog front end
The AD4112 is a low power, low noise, 24-bit, sigma-delta (Σ-Δ)
Up to 6.2 kSPS per channel (161 μs per channel)
analog-to-digital converter (ADC) that integrates an analog front
16 noise free bits at 1 kSPS per channel
end (AFE) for fully differential or single-ended, high impedance
85 dB rejection of 50 Hz and 60 Hz at 20 SPS per channel
(≥1 MΩ) bipolar, ±10 V voltage inputs, and 0 mA to 20 mA
±10 V inputs, 4 differential or 8 single-ended
current inputs.
Overrange up to ±20 V
The AD4112 also integrates key analog and digital signal
≥1 MΩ impedance
conditioning blocks to configure eight individual setups for
±0.06% accuracy at 25°C
each analog input channel in use. The AD4112 features a
0 mA to 20 mA inputs, 4 single-ended
maximum channel scan rate of 6.2 kSPS (161 μs) for fully
Overrange from −0.5 mA to +24 mA
settled data.
60 Ω impedance ±0.08% accuracy at 25°C
The embedded 2.5 V, low drift (5 ppm/°C), band gap internal
On-chip 2.5 V reference
reference (with output reference buffer) reduces the external
±0.12% accuracy at 25°C, ±5 ppm/°C (typical) drift
component count.
Internal or external clock
The digital filter allows flexible settings, including simultaneous
Power supplies
50 Hz and 60 Hz rejection at a 27.27 SPS output data rate. The
AVDD = 3.0 V to 5.5 V
user can select between the different filter settings depending on
IOVDD = 2 V to 5.5 V
the demands of each channel in the application. The automatic
Total IDD = 3.9 mA
channel sequencer enables the ADC to switch through each
Temperature range: −40°C to +105°C
enabled channel.
3-wire or 4-wire serial digital interface (Schmitt trigger on SCLK)
The precision performance of the AD4112 is achieved by
SPI, QSPI, MICROWIRE, and DSP compatible
integrating the proprietary iPassives™ technology from Analog
Devices, Inc. The AD4112 is factory calibrated to achieve a high
Process control
degree of specified accuracy.
PLC and DCS modules
The AD4112 operates with a single power supply, making it easy to use in galvanically isolated applications. The specified operating temperature range is −40°C to +105°C. The AD4112 is housed in a 40-lead, 6 mm × 6 mm LFCSP package.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING CHARACTERISTICS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS NOISE PERFORMANCE AND RESOLUTION THEORY OF OPERATION POWER SUPPLIES Single-Supply Operation (AVSS = DGND) DIGITAL COMMUNICATION AD4112 RESET CONFIGURATION OVERVIEW Channel Configuration Channel Registers ADC Setups Setup Configuration Registers Filter Configuration Registers Gain Registers Offset Registers ADC Mode and Interface Mode Configuration ADC Mode Register Interface Mode Register CIRCUIT DESCRIPTION MULTIPLEXER CURRENT INPUTS VOLTAGE INPUTS Fully Differential Inputs Single-Ended Inputs Adjusting Voltage Input Gain AD4112 REFERENCE Internal Reference External Reference BUFFERED REFERENCE INPUT CLOCK SOURCE Internal Oscillator External Crystal External Clock DIGITAL FILTER SINC5 + SINC1 FILTER SINC3 FILTER SINGLE CYCLE SETTLING ENHANCED 50 Hz AND 60 Hz REJECTION FILTERS OPERATING MODES CONTINUOUS CONVERSION MODE CONTINUOUS READ MODE SINGLE CONVERSION MODE STANDBY AND POWER-DOWN MODES CALIBRATION DIGITAL INTERFACE CHECKSUM PROTECTION CRC CALCULATION Polynomial Example of a Polynomial CRC Calculation—24-Bit Word: 0x654321 (Eight Command Bits and 16-Bit Data) XOR Calculation Example of an XOR Calculation—24-Bit Word: 0x654321 (Eight Command Bits and 16-Bit Data) INTEGRATED FUNCTIONS GENERAL-PURPOSE OUPUTS DELAY 16-BIT/24-BIT CONVERSIONS DOUT_RESET SYNCHRONIZATION Normal Synchronization Alternate Synchronization ERROR FLAGS ADC_ERROR CRC_ERROR REG_ERROR ERRORB Input/Output DATA_STAT IOSTRENGTH INTERNAL TEMPERATURE SENSOR APPLICATIONS INFORMATION GROUNDING AND LAYOUT REGISTER SUMMARY REGISTER DETAILS COMMUNICATIONS REGISTER STATUS REGISTER ADC MODE REGISTER INTERFACE MODE REGISTER REGISTER CHECK DATA REGISTER GPIO CONFIGURATION REGISTER ID REGISTER CHANNEL REGISTER 0 CHANNEL REGISTER 1 TO CHANNEL REGISTER 15 SETUP CONFIGURATION REGISTER 0 SETUP CONFIGURATION REGISTER 1 TO SETUP CONFIGURATION REGISTER 7 FILTER CONFIGURATION REGISTER 0 FILTER CONFIGURATION REGISTER 1 TO FILTER CONFIGURATION REGISTER 7 OFFSET REGISTER 0 OFFSET REGISTER 1 TO OFFSET REGISTER 7 GAIN REGISTER 0 GAIN REGISTER 1 TO GAIN REGISTER 7 OUTLINE DIMENSIONS ORDERING GUIDE
