LT1964 ABSOLUTE MAXIMUM RATINGS(Note 1) SHDN Pin Voltage IN Pin Voltage .. ±20V (with Respect to GND Pin) ..–20V, 15V OUT Pin Voltage (Note 11) ..±20V Output Short-Circuit Duration .. Indefi nite OUT to IN Differential Voltage (Note 11) .. –0.5V, 20V Operating Junction Temperature (E, I Grade) ADJ Pin Voltage Range (Note 10) ... – 40°C to 125°C (with Respect to IN Pin) (Note 11) ... –0.5V, 20V Storage Temperature Range ... –65°C to 150°C BYP Pin Voltage Lead Temperature (Soldering, 10 sec) (with Respect to IN Pin) ... ±20V SOT-23 Package .. 300°C SHDN Pin Voltage (with Respect to IN Pin) (Note 11) ... –0.5V, 35V PIN CONFIGURATION LT1964 LT1964-SD TOP VIEW TOP VIEW OUT 1 8 IN GND 1 5 OUT OUT 2 7 IN 9 IN 2 ADJ 3 6 GND SHDN 3 4 ADJ SHDN 4 5 BYP S5 PACKAGE 5-LEAD PLASTIC SOT-23 DD PACKAGE T 8-LEAD (3mm s 3mm) PLASTIC DFN JMAX = 150°C, θJA ≈125°C/W to 250°C/W (NOTE 13) TJMAX = 125°C, θJA = 40°C/W, θJC = 16°C/W SEE THE APPLICATIONS INFORMATION SECTION (NOTE 13) EXPOSED PAD (PIN 9) IS IN, MUST BE SOLDERED TO PCB LT1964-BYP LT1964-5 TOP VIEW TOP VIEW GND 1 5 OUT GND 1 5 OUT IN 2 IN 2 BYP 3 4 ADJ BYP 3 4 SHDN S5 PACKAGE S5 PACKAGE 5-LEAD PLASTIC SOT-23 5-LEAD PLASTIC SOT-23 TJMAX = 150°C, θJA ≈125°C/W to 250°C/W TJMAX = 150°C, θJA ≈125°C/W to 250°C/W (NOTE 13) (NOTE 13) SEE THE APPLICATIONS INFORMATION SECTION SEE THE APPLICATIONS INFORMATION SECTION ORDER INFORMATIONLEAD FREE FINISHTAPE AND REELPART MARKING*PACKAGE DESCRIPTIONTEMPERATURE RANGE LT1964ES5-SD#PBF LT1964ES5-SD#TRPBF LTVX 5-Lead Plastic SOT-23 –40°C to 125°C LT1964ES5-BYP#PBF LT1964ES5-BYP#TRPBF LTVY 5-Lead Plastic SOT-23 –40°C to 125°C LT1964ES5-5#PBF LT1964ES5-5#TRPBF LTVZ 5-Lead Plastic SOT-23 –40°C to 125°C LT1964EDD#PBF LT1964EDD#TRPBF LDVM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1964IS5-SD#PBF LT1964IS5-SD#TRPBF LTVX 5-Lead Plastic SOT-23 –40°C to 125°C LT1964IS5-BYP#PBF LT1964IS5-BYP#TRPBF LTVY 5-Lead Plastic SOT-23 –40°C to 125°C LT1964IS5-5#PBF LT1964IS5-5#TRPBF LTVZ 5-Lead Plastic SOT-23 –40°C to 125°C LT1964IDD#PBF LT1964IDD#TRPBF LDVM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C 1964fb 2
