Datasheet LT1964 (Analog Devices) - 3
Description200mA, Low Noise, Low Dropout Negative Micropower Regulator
Pages / Page16 / 3 — ORDER INFORMATION. LEAD BASED FINISH. TAPE AND REEL. PART MARKING*. …
File Format / SizePDF / 230 Kb
ORDER INFORMATION. LEAD BASED FINISH. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. TEMPERATURE RANGE
ORDER INFORMATION LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1964
LT1964ES5-SD LT1964ES5-SD#TR LTVX 5-Lead Plastic SOT-23 –40°C to 125°C LT1964ES5-BYP LT1964ES5-BYP#TR LTVY 5-Lead Plastic SOT-23 –40°C to 125°C LT1964ES5-5 LT1964ES5-5#TR LTVZ 5-Lead Plastic SOT-23 –40°C to 125°C LT1964EDD LT1964EDD#TR LDVM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT1964IS5-SD LT1964IS5-SD#TR LTVX 5-Lead Plastic SOT-23 –40°C to 125°C LT1964IS5-BYP LT1964IS5-BYP#TR LTVY 5-Lead Plastic SOT-23 –40°C to 125°C LT1964IS5-5 LT1964IS5-5#TR LTVZ 5-Lead Plastic SOT-23 –40°C to 125°C LT1964IDD LT1964IDD#TR LDVM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. PARAMETER CONDITIONS MIN TYP MAX UNITS
Regulated Output Voltage LT1964-5 VIN = –5.5V, ILOAD = –1mA –4.925 –5 –5.075 V (Notes 3, 9) –20V < VIN < –6V, –200mA < ILOAD < –1mA l –4.850 –5 –5.150 V ADJ Pin Voltage LT1964 VIN = –2V, ILOAD = –1mA –1.202 –1.22 –1.238 V (Notes 2, 3, 9) –20V < VIN < –2.8V, –200mA < ILOAD < –1mA l –1.184 –1.22 –1.256 V Line Regulation LT1964-5 ΔVIN = –5.5V to –20V, ILOAD = –1mA l 15 50 mV LT1964 (Note 2) ΔVIN = –2.8V to –20V, ILOAD = –1mA l 1 12 mV Load Regulation LT1964-5 VIN = –6V, ΔILOAD = –1mA to –200mA 15 35 mV VIN = –6V, ΔILOAD = –1mA to –200mA l 50 mV LT1964 VIN = –2.8V, ΔILOAD = –1mA to –200mA 2 7 mV VIN = –2.8V, ΔILOAD = –1mA to –200mA l 15 mV Dropout Voltage ILOAD = –1mA 0.1 0.15 V VIN = VOUT(NOMINAL) ILOAD = –1mA l 0.19 V (Notes 4, 5) ILOAD = –10mA 0.15 0.20 V ILOAD = –10mA l 0.25 V ILOAD = –100mA 0.26 0.33 V ILOAD = –100mA l 0.39 V ILOAD = –200mA 0.34 0.42 V ILOAD = –200mA l 0.49 V GND Pin Current ILOAD = 0mA l 30 70 μA VIN = VOUT(NOMINAL) ILOAD = –1mA l 85 180 μA (Notes 4, 6) ILOAD = –10mA l 300 600 μA ILOAD = –100mA l 1.3 3 mA ILOAD = –200mA l 2.5 6 mA 1964fb 3
