Datasheet VLMU35CM..-280-120 (Vishay)
ManufacturerVishay
DescriptionUVC Emitting Diode in SMD Package
Pages / Page7 / 1 — VLMU35CM..-280-120. UVC Emitting Diode in SMD Package. FEATURES. …
File Format / SizePDF / 243 Kb
VLMU35CM..-280-120. UVC Emitting Diode in SMD Package. FEATURES. DESCRIPTION. APPLICATIONS. PRODUCT GROUP AND PACKAGE DATA
Datasheet VLMU35CM..-280-120 Vishay
VLMU35CM..-280-120
UVC Emitting Diode in SMD Package FEATURES
• Ceramic SMT package with quartz window • Dimension (L x W x H) in mm: 3.5 x 3.5 x 1.2 • Forward current: up to 150 mA • Radiant power (typ.): 12 mW at 100 mA • Leads / terminations finish: gold plated (Au) • Reflow soldering method • MSL 3 according to J-STD-020 • Material categorization: for definitions of compliance please see
DESCRIPTION
www.vishay.com/doc?99912 VLMU35CM..-280-120 is a ceramic based mid power UVC
LED with quartz window for long life time. The package size • Sterilization is 3.5 mm x 3.5 mm x 1.2 mm and the radiant power typically 12 mW at 100 mA in a wavelength range of 265 nm to • Medical application 285 nm. • Sensing of gases, germs, DNA, ...
PRODUCT GROUP AND PACKAGE DATA SAFETY ADVICES
• Product group: LED Depending on the mode of operation, these devices emit • Package: SMD ceramic highly concentrated non visible ultraviolet light which can be hazardous to the human eye and skin. Products which • Product series: standard power UV LED incorporate these devices have to follow the safety • Angle of half intensity: ± 60° precautions given in IEC 62471 “Photobiological Safety of • Lead-finishing: Au Lamps and Lamp Systems”.
PARTS TABLE RADIANT POWER at WAVELENGTH at FORWARD VOLTAGE at PART COLOR (mW) I (nm) (V) F IF IF TECHNOLOGY (mA) (mA) (mA) MIN. TYP. MAX. MIN. TYP. MAX. MIN. TYP. MAX.
VLMU35CM00-280-120 Ultraviolet 8 12 - 100 265 278 285 100 4 5 7 100 AlGaN
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
VLMU35CM..-280-120 PARAMETER TEST CONDITION SYMBOL VALUE UNIT
DC forward current IF 150 mA Power dissipation PV 0.86 W Reverse voltage Not designed for reverse operation Electrostatic discharge HBM: MIL-STD-883 C 3B ESD 2000 V Junction temperature Tj +85 °C Operating temperature range Tamb -40 to +80 °C Storage temperature range Tstg -40 to +100 °C Solder temperature Tsol 260 °C Rev. 1.0, 29-Nov-2018
1
Document Number: 84938 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
