Datasheet VLMU35CM..-280-120 (Vishay) - 2
ManufacturerVishay
DescriptionUVC Emitting Diode in SMD Package
Pages / Page7 / 2 — VLMU35CM..-280-120. OPTICAL AND ELECTRICAL CHARACTERISTICS. …
File Format / SizePDF / 243 Kb
VLMU35CM..-280-120. OPTICAL AND ELECTRICAL CHARACTERISTICS. VLMU35CM..-280-120, ULTRAVIOLET PARAMETER. TEST CONDITION. SYMBOL
VLMU35CM..-280-120 OPTICAL AND ELECTRICAL CHARACTERISTICS VLMU35CM..-280-120, ULTRAVIOLET PARAMETER TEST CONDITION SYMBOL
VLMU35CM..-280-120
(Tamb = 25 °C, unless otherwise specified)
VLMU35CM..-280-120, ULTRAVIOLET PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Forward voltage IF = 100 mA VF 4 5 7 V Radiant power IF = 100 mA φe 8 12 - mW Ratio of radiant intensity/radiant power IF = 100 mA Ie/φe - 0.28 - sr-1 Peak wavelength IF = 100 mA λp 265 278 285 nm Angle of half intensity IF = 100 mA ϕ - ± 60 - ° Thermal resistance junction to solder pin RthJS - 15 - K/W Soldered on 20 x 20 x 1.7 (in mm) Thermal resistance junction to ambient R Al MCPCB thJA - 30 - K/W
Note
• Tolerances: ± 11 % for φe, ± 0.1 V for VF, ± 3 nm for λp
RADIANT POWER CLASSIFICATION
(IF = 100 mA)
GROUP MIN. MAX. UNIT
X3 8 10 X4 10 12 X5 12 14 mW X6 14 16 X7 16 18
PEAK WAVELENGTH CLASSIFICATION
(IF = 100 mA)
W1 265 285 nm
FORWARD VOLTAGE CLASSIFICATION
(IF = 100 mA)
VX 4 5 VY 5 6 V V0 6 7
Note
• In order to ensure availability, single groups for radiant intensity, wavelength, and forward voltage will not be orderable. Only one group for radiant intensity, wavelength, and forward voltage will be shipped in any one reel Rev. 1.0, 29-Nov-2018
2
Document Number: 84938 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
