DatasheetsDatasheet ADSP-SC582, ADSP-SC583, ADSP-SC584, …
Datasheet ADSP-SC582, ADSP-SC583, ADSP-SC584, ADSP-SC587, ADSP-SC589, ADSP-21583, ADSP-21584, ADSP-21587 (Analog Devices)
Description | SHARC+ Dual-Core DSP with Arm Cortex-A5 |
Pages / Page | 173 / 1 — SHARC+ Dual-Core. DSP with Arm Cortex-A5. ADSP-SC582/. SC583. /SC584. … |
Revision | B |
File Format / Size | PDF / 4.5 Mb |
SHARC+ Dual-Core. DSP with Arm Cortex-A5. ADSP-SC582/. SC583. /SC584. /SC587. /SC589. /ADSP-21583. /21584. /21587. SYSTEM FEATURES
SHARC+ Dual-Core DSP with Arm Cortex-A5 ADSP-SC582/ SC583 /SC584 /SC587 /SC589 /ADSP-21583 /21584 /21587 SYSTEM FEATURES 19 mm × 19 mm 349/529 BGA (0.8 pitch), RoHS compliant Dual enhanced SHARC+ high performance floating-point Low system power across automotive temperature range cores MEMORY Up to 500 MHz per SHARC+ core Large on-chip L2 SRAM with ECC protection, up to 256 kB Up to 5 Mb (640 kB) Level 1 (L1) SRAM memory per core On-chip L2 ROM (512 kB) with parity (optional ability to configure as cache) Two Level 3 (L3) interfaces optimized for low system power, 32-bit, 40-bit, and 64-bit floating-point support providing a 16-bit interface to DDR3 (supporting 1.5 V 32-bit fixed point capable DDR3L devices), DDR2, or LPDDR1 SDRAM devices Byte, short-word, word, long-word addressed ADDITIONAL FEATURES Arm Cortex-A5 core 500 MHz/800 DMIPS with NEON/VFPv4-D16/Jazelle Security and Protection 32 kB L1 instruction cache/32 kB L1 data cache Cryptographic hardware accelerators 256 kB Level 2 (L2) cache with parity Fast secure boot with IP protection Powerful DMA system Support for Arm TrustZone On-chip memory protection Accelerators Integrated safety features High performance pipelined FFT/IFFT engine FIR, IIR, HAE, SINC offload engines AEC-Q100 qualified for automotive applications SYSTEM CONTROL PERIPHERALS SIGNAL ROUTING UNIT (SRU) SECURITY AND PROTECTION 2×2 PRECISION CLOCK SYSTEM PROTECTION (SPU) CORE 0 CORE 1 CORE 2 GENERATORS 2x DAI SYSTEM MEMORY ASRC FULL SPORT 2x PIN ® PROTECTION UNIT (SMPU) Arm Cortex-A5 ®
S S
2×4 PAIRS 2×4 BUFFER 40–28 FAULT MANAGEMENT 2×1 S/PDIF Rx/Tx Arm® TrustZone® SECURITY 3× I2C DUAL CRC L1 CACHE 6 32 kB L1 I-CACHE L1 SRAM (PARITY) L1 SRAM (PARITY) 2× LINK PORTS WATCHDOGS 32 kB L1 D-CACHE 2× SPI + 1× QUAD SPI OTP MEMORY 5 Mb (640 kB) 5 Mb (640 kB) L2 CACHE SRAM/CACHE SRAM/CACHE 3× UARTs THERMAL MONITOR UNIT (TMU) 256 kB (PARITY) 1× EPPI PROGRAM FLOW 3× ePWM SYS EVENT CORE 0 (GIC) 8× TIMERS + 1× COUNTER G SYS EVENT CORES 1-2 (SEC) SYSTEM CROSSBAR AND DMA SUBSYSTEM ADC CONTROL MODULE P TRIGGER ROUTING (TRU) (ACM) I O ASYNC MEMORY (16-BIT) 102–80 CLOCK, RESET, AND POWER 2× CAN2.0 CLOCK GENERATION (CGU) SD/SDIO/eMMC CLOCK DISTRIBUTION L3 MEMORY SYSTEM SYSTEM UNIT (CDU) INTERFACES L2 MEMORY ACCELERATION MLB 3-PIN REAL TIME CLOCK (RTC) DDR3 DDR3 SRAM DSP FUNCTIONS 2× EMAC ROM ROM DDR2 DDR2 (ECC) (FFT/IFFT, FIR, IIR, HAE/SINC) RESET CONTROL (RCU) 2 Mb 2 Mb SINC FILTER LPDDR1 LPDDR1 2 Mb (256 kB) (256 kB) (256 kB) POWER MANAGEMENT (DPM) ENCRYPTION/DECRYPTION 8x SHARC FLAGS 10 16 16 2× USB 2.0 HS DEBUG UNIT 6 DATA DATA MLB 6-PIN Arm® CoreSightTM 7 PCIe2.0 (1 lane) WATCHPOINTS (SWU) HADC (8 CHAN, 12-BIT) 8
Figure 1. Processor Block Diagram SHARC, SHARC+, and the SHARC logo are registered trademarks of Analog Devices, Inc.
Rev. B Do cument Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 U.S.A. or otherwise under any patent or patent rights of Analog Devices. Trademarks and Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline System Features Memory Additional Features Table of Contents Revision History General Description ARM Cortex-A5 Processor Generic Interrupt Controller (GIC), PL390 (ADSP-SC58x Only) Generic Interrupt Controller Port0 (GICPORT0) Generic Interrupt Controller Port1 (GICPORT1) L2 Cache Controller, PL310 (ADSP-SC58x Only) SHARC Processor L1 Memory L1 Master and Slave Ports L1 On-Chip Memory Bandwidth Instruction and Data Cache System Event Controller (SEC) Input Core Memory-Mapped Registers (CMMR) SHARC+ Core Architecture SIMD Computational Engine Independent, Parallel Computation Units Core Timer Data Register File Context Switch Universal Registers (USTAT) Data Address Generators With Zero-Overhead Hardware Circular Buffer Support Flexible Instruction Set Architecture (ISA) Variable Instruction Set Architecture (VISA) Single-Cycle Fetch of Instructional Four Operands Core Event Controller (CEC) Instruction Conflict-Cache Branch Target Buffer/Branch Predictor Addressing Spaces Additional Features System Infrastructure System L2 Memory SHARC+ Core L1 Memory in Multiprocessor Space One Time Programmable Memory (OTP) I/O Memory Space System Memory Map System Crossbars (SCBs) Direct Memory Access (DMA) Memory Direct Memory Access (MDMA) Extended Memory DMA Cyclic Redundant C ode (CRC) Protection Event Handling System Event Controller (SEC) Trigger Routing Unit (TRU) Security Features Arm TrustZone Cryptographic Hardware Accelerators System Protection Unit (SPU) System Memory Protection Unit (SMPU) Security Features Disclaimer Safety Features Multiparity Bit Protected SHARC+ Core L1 Memories Error Correcting Codes (ECC) Protected L2 Memories Cyclic Redundant Code (CRC) Protected Memories Signal Watchdogs System Event Controller (SEC) Processor Peripherals Dynamic Memory Controller (DMC) Digital Audio Interface (DAI) Serial Ports (SPORTs) Asynchronous Sample Rate Converter (ASRC) S/PDIF-Compatible Digital Audio Receiver/Transmitter Precision Clock Generators (PCG) Enhanced Parallel Peripheral Interface (EPPI) Universal Asynchronous Receiver/Transmitter (UART) Ports Serial Peripheral Interface (SPI) Ports Link Ports (LP) ADC Control Module (ACM) Interface 3-Phase Pulse Width Modulator (PWM) Units Ethernet Media Access Controller (EMAC) Audio Video Bridging (AVB) Support (10/100/1000 EMAC Only) Precision Time Protocol (PTP) IEEE 1588 Support Controller Area Network (CAN) Timers General-Purpose (GP) Timers (TIMER) Watchdog Timer (WDT) General-Purpose Counters (CNT) PCI Express (PCIe) Housekeeping Analog-to-Digital Converter (HADC) USB 2.0 On the Go (OTG) Dual-Role Device Controller Media Local Bus (Media LB) 2-Wire Controller Interface (TWI) General-Purpose I/O (GPIO) Pin Interrupts Mobile Storage Interface (MSI) System Acceleration FFT/IFFT Accelerator Finite Impulse Response (FIR) Accelerator Infinite Impulse Response (IIR) Accelerator Harmonic Analysis Engine (HAE) Sinus Cardinalis (SINC) Filter Digital Transmission Content Protection (DTCP) System Design Clock Management Reset Control Unit (RCU) Real-Time Clock (RTC) Clock Generation Unit (CGU) System Crystal Oscillator and USB Crystal Oscillator Clock Distribution Unit (CDU) Power-Up Clock Out/External Clock Booting Thermal Monitoring Unit (TMU) Power Supplies Power Management Target Board JTAG Emulator Connector System Debug System Watchpoint Unit (SWU) Debug Access Port (DAP) Development Tools Integrated Development Environments (IDEs) EZ-KIT Lite Evaluation Board EZ-KIT Lite Evaluation Kits Software Add-Ins for CrossCore Embedded Studio Board Support Packages for Evaluation Hardware Middleware Packages Algorithmic Modules Designing an Emulator-Compatible DSP Board (Target) Additional Information Related Signal Chains ADSP-SC58x/ADSP-2158x Detailed Signal Descriptions 349-Ball CSP_BGA Signal Descriptions GPIO Multiplexing for the 349-Ball CSP_BGA Package 529-Ball CSP_BGA Signal Descriptions GPIO Multiplexing for the 529-Ball CSP_BGA Package ADSP-SC58x/ADSP-2158x Designer Quick Reference Specifications Operating Conditions Clock Related Operating Conditions Electrical Characteristics Total Internal Power Dissipation Application Dependent Current Clock Current Current from High Speed Peripheral Operation Data Transmission Current HADC HADC Electrical Characteristics HADC DC Accuracy HADC Timing Specifications TMU TMU Characteristics Absolute Maximum Ratings ESD Caution Timing Specifications Power-Up Reset Timing Clock and Reset Timing Asynchronous Read SMC Read Cycle Timing With Reference to SYS_CLKOUT Asynchronous Flash Read Asynchronous Page Mode Read Asynchronous Write SMC Write Cycle Timing With Reference to SYS_CLKOUT Asynchronous Flash Write All Accesses DDR2 SDRAM Clock and Control Cycle Timing DDR2 SDRAM Read Cycle Timing DDR2 SDRAM Write Cycle Timing Mobile DDR (LPDDR) SDRAM Clock and Control Cycle Timing Mobile DDR SDRAM Read Cycle Timing Mobile DDR SDRAM Write Cycle Timing DDR3 SDRAM Clock and Control Cycle Timing DDR3 SDRAM Read Cycle Timing DDR3 SDRAM Write Cycle Timing Enhanced Parallel Peripheral Interface (EPPI) Timing Link Ports (LP) Serial Ports (SPORT) Sample Rate Converter—Serial Input Port Sample Rate Converter—Serial Output Port SPI Port—Master Timing SPI Port—Slave Timing SPI Port—SPI Ready (SPIx_RDY) Slave Timing SPI Port—Open Drain Mode (ODM) Timing SPI Port—SPIx_RDY Master Timing Precision Clock Generator (PCG) (Direct Pin Routing) General-Purpose I/O Port Timing General-Purpose I/O Timer Cycle Timing DAIx Pin to DAIx Pin Direct Routing (DAI0 Block and DAI1 Block) Up/Down Counter/Rotary Encoder Timing Pulse Width Modulator (PWM) Timing PWM — Medium Precision (MP) Mode Timing PWM — Heightened Precision (HP) Mode Timing ADC Controller Module (ACM) Timing Universal Asynchronous Receiver-Transmitter (UART) Ports—Receive and Transmit Timing Controller Area Network (CAN) Interface Universal Serial Bus (USB) PCI Express (PCIe) 10/100 EMAC Timing (ETH0 and ETH1) 10/100/1000 EMAC Timing (ETH0 Only) Sinus Cardinalis (SINC) Filter Timing Sony/Philips Digital Interface (S/PDIF) Transmitter S/PDIF Transmitter Serial Input Waveforms S/PDIF Transmitter Input Data Timing Oversampling Clock (TxCLK) Switching Characteristics S/PDIF Receiver Internal Digital PLL Mode Media LB (MLB) Mobile Storage Interface (MSI) Controller Timing Program Trace Macrocell (PTM) Timing Debug Interface (JTAG Emulation Port) Timing Output Drive Currents Test Conditions Output Enable Time Measurement Output Disable Time Measurement Capacitive Loading Environmental Conditions ADSP-SC58x/ADSP-2158x 349-Ball BGA Ball Assignments ADSP-SC58x/ADSP-2158x 349-Ball BGA Ball Assignments (Numerical by Ball Number) ADSP-SC58x/ADSP-2158x 349-Ball BGA Ball Assignments (Alphabetical by Pin Name) Configuration of the 349-Ball CSP_BGA ADSP-SC58x/ADSP-2158x 529-Ball BGA Ball Assignments ADSP-SC58x/ADSP-2158x 529-Ball BGA Ball Assignments (Numerical by Ball Number) ADSP-SC58x/ADSP-2158x 529-Ball BGA Ball Assignments (Alphabetical by Pin Name) Configuration of the 529-Ball CSP_BGA Outline Dimensions Surface-Mount Design Automotive Products Ordering Guide
