Datasheet 2N7000, 2N7002, NDS7002A (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionN-Channel Enhancement Mode Field Effect Transistor
Pages / Page8 / 2 — 2N7000 / 2N7002 / NDS7002A — N-Chan. Absolute Maximum Ratings. Value. …
Revision3
File Format / SizePDF / 775 Kb
2N7000 / 2N7002 / NDS7002A — N-Chan. Absolute Maximum Ratings. Value. Symbol. Parameter. Unit. 2N7000. 2N7002. NDS7002A. nel Enh
2N7000 / 2N7002 / NDS7002A — N-Chan Absolute Maximum Ratings Value Symbol Parameter Unit 2N7000 2N7002 NDS7002A nel Enh
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be opera- ble above the recommended operating conditions and stressing the parts to these levels is not recommended. In addi- tion, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TC = 25°C unless otherwise noted.
VDSS Drain-to-Source Voltage 60 V VDGR Drain-Gate Voltage (RGS ≤ 1 M 60 V VGSS Gate-Source Voltage - Continuous ±20 V Gate-Source Voltage - Non Repetitive (tp < 50 S) ±40 ID Maximum Drain Current - Continuous 200 115 280 mA Maximum Drain Current - Pulsed 500 800 1500 PD Maximum Power Dissipation Derated above 25°C 400 200 300 mW 3.2 1.6 2.4 mW/°C
nel Enh
TJ, TSTG Operating and Storage Temperature Range -55 to 150 -65 to 150 °C TL Maximum Lead Temperature for Soldering Purposes, 300 °C 1/16-inch from Case for 10 Seconds
a ncement Mode Field Effect T Thermal Characteristics
. Value Symbol Parameter Unit 2N7000 2N7002 NDS7002A
R Thermal Resistance, Junction to Ambient JA 312.5 625 417 °C/W
Electrical Characteristics
Symbol Parameter Conditions Type Min. Typ. Max. Unit Off Characteristics ransisto
Drain-Source Breakdown BVDSS V Voltage GS = 0 V, ID = 10 A Al 60 V IDSS Zero Gate Voltage Drain VDS = 48 V, VGS = 0 V 2N7000 1 A Current V 1
r
DS = 48 V, VGS = 0 V, mA TC = 125°C VDS = 60 V, VGS = 0 V 2N7002 1 A NDS7002A VDS = 60 V, VGS = 0 V, 0.5 mA TC = 125°C IGSSF Gate - Body Leakage, VGS = 15 V, VDS = 0 V 2N7000 10 nA Forward VGS = 20 V, VDS = 0 V 2N7002 100 nA NDS7002A IGSSR Gate - Body Leakage, VGS = -15 V, VDS = 0 V 2N7000 -10 nA Reverse VGS = -20 V, VDS = 0 V 2N7002 -100 nA NDS7002A www.onsemi.com 2
