Datasheet Si8931/32 (Silicon Labs) - 2
ManufacturerSilicon Labs
DescriptionIsolated Amplifier for Voltage Measurement
Pages / Page31 / 2 — 1. Ordering Guide. New Ordering Part. Ordering Options. Number (OPN). …
Revision0.5
File Format / SizePDF / 579 Kb
1. Ordering Guide. New Ordering Part. Ordering Options. Number (OPN). Input Range. Isolation Rating. Output. Package Type. Note:
1 Ordering Guide New Ordering Part Ordering Options Number (OPN) Input Range Isolation Rating Output Package Type Note:
Si8931/32 Data Sheet Ordering Guide
1. Ordering Guide New Ordering Part Ordering Options Number (OPN) Input Range Isolation Rating Output Package Type
Si8931D-IS4 0 to 2.5 V nominal 5.0 kVrms Differential WB Stretched SOIC-8 Si8931B-IS 0 to 2.5 V nominal 2.5 kVrms Differential NB SOIC-8 Si8932D-IS4 0 to 2.5 V nominal 5.0 kVrms Single-ended WB Stretched SOIC-8 Si8932B-IS 0 to 2.5 V nominal 2.5 kVrms Single-ended NB SOIC-8
Note:
1. All packages are RoHS-compliant. 2. “Si” and “SI” are used interchangeably. 3. AEC-Q100 pending qualification.
silabs.com
| Building a more connected world. Preliminary Rev. 0.5 | 2 Document Outline 1. Ordering Guide 2. System Overview 3. Voltage Sense Application 4. Electrical Specifications 4.1 Regulatory Information 4.2 Typical Operating Characteristics 5. Pin Descriptions 5.1 Si8931 Pin Descriptions 5.2 Si8932 Pin Descriptions 6. Packaging 6.1 Package Outline: 8-Pin Wide Body Stretched SOIC 6.2 Package Outline: 8-Pin Narrow Body SOIC 6.3 Land Pattern: 8-Pin Wide Body Stretched SOIC 6.4 Land Pattern: 8-Pin Narrow Body SOIC 6.5 Top Marking: 8-Pin Wide Body Stretched SOIC 6.6 Top Marking: 8-Pin Narrow Body SOIC 7. Document Revision History
