Datasheet VOT8123AB, VOT8123AD, VOT8123AG (Vishay) - 2
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, Non-Zero Crossing, High dV/dt, Low Input Current
Pages / Page11 / 2 — VOT8123AB, VOT8123AD, VOT8123AG. ABSOLUTE MAXIMUM RATINGS. PARAMETER. …
Revision1.1
File Format / SizePDF / 186 Kb
VOT8123AB, VOT8123AD, VOT8123AG. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. INPUT. OUTPUT. COUPLER. Note
VOT8123AB, VOT8123AD, VOT8123AG ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT INPUT OUTPUT COUPLER Note
(Tamb = 25 °C, unless otherwise specified)
Reverse voltage VR 6 V Forward current IF 50 mA Power dissipation Pdiss 120 mW Junction temperature Tj 125 °C
OUTPUT
Peak off-state voltage VDRM 800 V On-state current IT(RMS) 100 mA Peak repetitive surge current PW = 1 ms, 120 pps ITSM 1 A Power dissipation Pdiss 300 mW Junction temperature Tj 125 °C
COUPLER
Storage temperature range Tstg -55 to +125 °C Ambient temperature range Tamb -40 to +110 °C Total power dissipation Pdiss 330 mW Soldering temperature For 10 s Tsld 260 °C
Note
• Stresses in excess of the absolute maximum ratings can cause permanent damage to the device. Functional operation of the device is not implied at these or any other conditions in excess of those given in the operational sections of this document. Exposure to absolute maximum ratings for extended periods of the time can adversely affect reliability. This phototriac should not be used to drive a load directly. It is intended to be a trigger device only Axis Title Axis Title 60 10000 120 10000 ) A A (m 50 100 rrent u 40 1000 Current (m 80 1000 ard tate C ne ne ne ine ne ine 30 60 Forw 1st li 2nd li On-S 1st li 2nd l 2nd l 2nd li um um 20 100 40 100 im im ax ax M M - 10 - 20 x. x. a a I F m I T m 0 10 0 10 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 T - Ambient Temperature (°C) T - Ambient Temperature (°C) amb amb Fig. 1 - Maximum Forward Current vs. Ambient Temperature Fig. 2 - Maximum On-State Current vs. Ambient Temperature Rev. 1.1, 29-Oct-2018
2
Document Number: 84926 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
