SLMA Series AUTOMOTIVE RELAY 20A/35A 20.8 AX MAX Features 15.8M X ·35A switching capability A M .2 2 ·Extended temp.range upto 125℃ 2 ·Dustproof and sealed type available Ordering Information Contact Rating SLMA-12-S-1- R-C Contact arrangment A /B/C A/B/C Voltage drop ≤200mV Contact arrangment Contact material R:resistor/D:diode Silver alloy:AgCdO、AgSnO2、AgNi Without w : ithout parallel components c Parallel oil components Contact rating 1.PCB type 20A/35A 14VDC 2.Plastic bracket, QC terminal 3.Metal bracket, QC terminal Max switching voltage 30VDC Without: QC terminal Version Max switching current 35A (Resistive 14VDC) S sealed / F dustproof Construction 12VDC/ 24VDC Min contact load 1A 6VDC Coil Voltage Electrical endurance 1x10 5ops (frequency: 900 ops/h) Part number 7 endurance Mechanical 1x10 ops (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system Class B / Class F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ(500VDC) W VDC ± Ω 10% Ω voltage voltage allowable Dielectric Between contacts 550VAC 1minute 1. 5 12 96 Strength and coil Between open 1. 7 12 96 680 550VAC 1minute contacts 70%Max 10%Min 130% 1. 5 24 384 ≤ Operate time(Under nominal voltage) 10ms 1. 7 24 384 2700 ≤10ms Release time(Under nominal voltage) Humidity 85% RH(20℃) Ambient Temperature -40℃~+125℃ Functional 98m/s ² Shock resistance Destructive 980m/s ² Vibration resistance 5Hz ~ 22.3Hz 10mm ( Double amplitude) Approx 16g Weight Dustproof and Sealed type Construction Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
