Datasheet SQ6 (Songle Relay)
ManufacturerSongle Relay
DescriptionAutomotive Relay
Pages / Page2 / 1 — SQ6. SERIES. Features. ·Small. size,. high. contact. current. …
File Format / SizePDF / 4.0 Mb
SQ6. SERIES. Features. ·Small. size,. high. contact. current. ·Environmental. temperature. :. -40℃~+125℃. ·Dust. proof,. reliable. work. ·Convenient
Datasheet SQ6 Songle Relay
SQ6 SERIES Features ·Small size, high contact current ·Environmental temperature : -40℃~+125℃ ·Dust proof, reliable work ·Convenient installation and use ·Available for 100A/180A selection Ordering Information Contact Rating SQ6-12VDC-R Contact arrangment A Voltage drop ≤200mV Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact rating 100A 180A R:Pressure sensitive resistance D:resistor/diode Max switching voltage 50VDC without:without parallel components c Parallel oil components Max switching current 180A 12VDC / 24VDC Max switching power 2400W Coil Voltage Work time limited ≤5min Part number Electrical endurance 5 ≥ 0000ops Characteristics Coil Data ( 20 at ℃) Insulation system Class B / Class F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ(500VDC) W VDC mA ± Ω 10% voltage voltage allowable Dielectric Between contacts 550VAC 1Minute 12 2.18 5.5 ≤8V 1V~3V 130% Strength and coil Between open 24 1.09 22 ≤ 130% 550VAC 1Minute 16V 1V~4V contacts ≤ Operate time(Under nominal voltage) 2 5 ms 26W Release time(Under nominal voltage) ≤10ms Humidity 85% RH(20℃) Ambient Temperature -40℃~+125℃ Functional 98m/s
²
Shock resistance Destructive 980m/s
²
Vibration resistance 10Hz
55Hz 1
5mm ( Double amplitude) Approx 235g Weight Construction Sealed Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
