Datasheet 2N5210 (Fairchild)
ManufacturerFairchild
DescriptionNPN General Purpose Amplifier
Pages / Page7 / 1 — 2N5210/MMBT5210. NPN General Purpose Amplifier. TO-92. SOT-23. Mark: 3M. …
RevisionB
File Format / SizePDF / 92 Kb
2N5210/MMBT5210. NPN General Purpose Amplifier. TO-92. SOT-23. Mark: 3M. Absolute Maximum Ratings*. Symbol. Parameter. Value. Units. NOTES
Datasheet 2N5210 Fairchild, Revision: B
2N5210/MMBT5210 2N5210/MMBT5210 NPN General Purpose Amplifier C
This device is designed for low noise, high gain, general purpose amplifier applications at collector currents from 1µA to 50 mA.
E C TO-92 BE B SOT-23 Mark: 3M Absolute Maximum Ratings*
TA = 25°C unless otherwise noted
Symbol Parameter Value Units
VCEO Collector-Emitter Voltage 50 V VCBO Collector-Base Voltage 50 V VEBO Emitter-Base Voltage 4.5 V IC Collector Current - Continuous 100 mA TJ, Tstg Operating and Storage Junction Temperature Range -55 to +150 °C *These ratings are limiting values above which the serviceability of any semiconductor device may be impaired.
NOTES
1)
These ratings are based on a maximum junction temperature of 150 degrees C.
2)
These are steady state limits. The factory should be consulted on applications involving pulsed or low duty cycle operations.
Thermal Characteristics
Max. Symbol Characteristic Units 2N5210 MMBT5210
P Total Device Dissipation 625 350 mW D Derate above 25°C 5.0 2.8 mW/°C Rθ Thermal Resistance, Junction to Case 83.3 °C/W JC Rθ Thermal Resistance, Junction to Ambient 200 357 °C/W JA 2002 Fairchild Semiconductor Corporation 2N5210, Rev B
