Datasheet MMBT3906 (Diodes) - 2
ManufacturerDiodes
DescriptionPNP
Pages / Page7 / 2 — MMBT3906. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. …
File Format / SizePDF / 262 Kb
MMBT3906. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. ESD Ratings. JEDEC Class
MMBT3906 Absolute Maximum Ratings Characteristic Symbol Value Unit Thermal Characteristics ESD Ratings JEDEC Class
(@TA = +25°C, unless otherwise specified.)
Collector-Base Voltage VCBO -40 V Collector-Emitter Voltage VCEO -40 V Emitter-Base Voltage VEBO -6.0 V Collector Current IC -200 mA Peak Collector Current ICM -200 mA Peak Base Current IBM -100 mA
(Note 6) 310 Power Dissipation PD mW (Note 7) 350 (Note 6) 403 Thermal Resistance, Junction to Ambient RϴJA °C/W (Note 7) 357 Thermal Resistance, Junction to Leads (Note 8) RϴJL 350 °C/W Operating and Storage Temperature Range TJ,TSTG -55 to +150 °C
ESD Ratings
(Note 9)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge—Human Body Model ESD HBM 4000 V 3A Electrostatic Discharge—Machine Model ESD MM 400 V C Notes: 6. For a device mounted on minimum recommended pad layout 1oz copper that is on a single-sided FR4 PCB; the device is measured under still air conditions while operating in a steady-state. 7. Same as Note 6 except the device is mounted on 15 mm × 15mm 1oz copper. 8. Thermal resistance from junction to solder-point (at the end of the leads). 9. Refer to JEDEC specification JESD22-A114 and JESD22-A115. MMBT3906 2 of 7 June 2018 Document number: DS30059 Rev. 21 - 2
www.diodes.com
© Diodes Incorporated Document Outline Mechanical Data Characteristic Features Marking Information Package Outline Dimensions Suggested Pad Layout
