Datasheet ADL5610 (Analog Devices)
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page16 / 1 — 30 MHz to 6 GHz. RF/IF Gain Block. Data Sheet. ADL5610. FEATURES. …
RevisionB
File Format / SizePDF / 558 Kb
30 MHz to 6 GHz. RF/IF Gain Block. Data Sheet. ADL5610. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Fixed gain of 18.4 dB. GND. (2)
Datasheet ADL5610 Analog Devices, Revision: B
30 MHz to 6 GHz RF/IF Gain Block Data Sheet ADL5610 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 18.4 dB GND (2) Broad operation from 30 MHz to 6 GHz High dynamic range gain block ADL5610 Input and output internally matched to 50 Ω Integrated bias circuit BIAS OIP3 of 38.8 dBm at 900 MHz 1 2 3
001
P1dB of 20.4 dBm at 900 MHz RFIN GND RFOUT
11507-
Noise figure of 2.2 dB at 900 MHz
Figure 1.
Single 5 V power supply Low quiescent current of 92 mA Wide operating temperature range of −40°C to +105°C Thermally efficient SOT-89 package ESD rating of ±1.5 kV (Class 1C) GENERAL DESCRIPTION
The ADL5610 is a single-ended RF/IF gain block amplifier that output, making the ADL5610 easy to implement in a wide provides broadband operation from 30 MHz to 6 GHz. The variety of applications. The only external parts required are the ADL5610 provides a low noise figure of 2.2 dB with a very high input and output ac coupling capacitors, power supply decoupling OIP3 of more than 38 dBm simultaneously, which delivers a capacitors, and bias inductor. high dynamic range. The ADL5610 has a high ESD rating of ±1.5 kV (Class 1C) and The ADL5610 provides a gain of 18 dB, which is stable over is fully specified for operation across a wide temperature range frequency, temperature, and power supply, and from device to of −40°C to +105°C. device. The amplifier is offered in the industry-standard SOT-89 A ful y populated RoHS-compliant evaluation board is available. package and is internal y matched to 50 Ω at the input and
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 6 GHz Frequency Band 30 MHz to 500 MHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
