Datasheet ADL5544 (Analog Devices) - 6
Description | 30 MHz to 6 GHz RF/IF Gain Block |
Pages / Page | 20 / 6 — ADL5544. Data Sheet. Frequency. S11. S21. S12. S22. (MHz). Magnitude (dB) … |
Revision | A |
File Format / Size | PDF / 393 Kb |
ADL5544. Data Sheet. Frequency. S11. S21. S12. S22. (MHz). Magnitude (dB) Angle (°)
ADL5544 Data Sheet Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
4700 −9.15961 179.4184 15.18857 −17.5037 −24.3599 −109.077 −8.00124 149.4702 4800 −8.81402 177.4327 15.08704 −21.4903 −24.4618 −111.079 −7.96813 149.7089 4900 −8.53104 175.2276 14.98061 −25.462 −24.5534 −113.068 −8.06461 149.4032 5000 −8.30896 172.6355 14.92996 −29.3613 −24.6449 −114.946 −8.27561 148.5568 5100 −8.09121 170.0194 14.84603 −33.2282 −24.7131 −116.819 −8.51734 146.6025 5200 −7.92674 167.1306 14.7721 −37.1236 −24.7652 −118.67 −8.77718 143.5944 5300 −7.79364 163.9153 14.72301 −41.0236 −24.8151 −120.546 −8.99346 139.518 5400 −7.6793 160.6589 14.64549 −45.0881 −24.8399 −122.534 −9.12197 134.7305 5500 −7.61523 156.9392 14.59131 −49.1815 −24.8628 −124.569 −9.17338 129.7103 5600 −7.60815 152.7976 14.53579 −53.2876 −24.8758 −126.604 −9.15423 124.593 5700 −7.54914 148.5617 14.47484 −57.5187 −24.8597 −128.793 −9.05211 119.5068 5800 −7.51209 143.7768 14.45495 −61.7253 −24.8296 −131.021 −9.00726 114.4158 5900 −7.46152 138.6641 14.42222 −66.0417 −24.7902 −133.375 −9.00598 109.1347 6000 −7.35914 133.6743 14.38015 −70.439 −24.7398 −135.849 −9.00546 103.4141 Rev. A | Page 6 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
