Datasheet ADL5544 (Analog Devices) - 9
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page20 / 9 — Data Sheet. ADL5544. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz …
File Format / SizePDF / 393 Kb
Data Sheet. ADL5544. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND. ) m. , dB. 900MHz. dB (. 700MHz. 2140MHz. OIP3
Data Sheet ADL5544 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND ) m , dB 900MHz dB ( 700MHz 2140MHz OIP3
Data Sheet ADL5544 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 40 40 ) m 35 , dB 900MHz 35 dB ( 30 700MHz 3 2140MHz OIP3 1900MHz , OIP 25 30 dB 1 Bm) d , P 20 2600MHz IN 3 ( 3500MHz GAIN IP O 25 , GA 15 E R P1dB 4000MHz 10 FIGU 20 E 5 NOISE FIGURE OIS N 0 15 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
003
–12 –10 –8 –6 –4 –2
006
FREQUENCY (GHz)
1384- 1384- 1
POUT PER TONE (dBm)
1 Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. OIP3 vs. Output Power (POUT) and Frequency
19.0 0 18.5 –5 18.0 –40°C 17.5 ) B +25°C –10 17.0 S (d B) d ER S22 16.5 N ( –15 AI MET G A 16.0 R +85°C –20 15.5 S-PA S12 S11 +105°C 15.0 –25 14.5 14.0 –30 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
004
007
FREQUENCY (GHz)
1384- 1
FREQUENCY (GHz)
1384- 1 Figure 4. Gain vs. Frequency and Temperature Figure 7. Input Return Loss (S11), Output Return Loss (S22), and Reverse Isolation (S12) vs. Frequency
40 40 6.0 –40°C +25°C 35 35 5.5 +85°C 5.0 30 30 ) +105°C dB 4.5 ( 25 25 E Bm) Bm) R d d +85°C 4.0 B ( 3 ( +105°C FIGU 1d 20 20 IP E +25°C P O –40°C 3.5 +25°C OIS N 15 15 –40°C 3.0 10 10 2.5 +105°C +85°C 5 5 2.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
005
008
FREQUENCY (GHz)
1384- 1
FREQUENCY (GHz)
1384- 1 Figure 5. P1dB and OIP3 vs. Frequency and Temperature Figure 8. Noise Figure vs. Frequency and Temperature Rev. A | Page 9 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
