ADL5602Data SheetParameterConditionsMinTypMaxUnit FREQUENCY = 900 MHz Gain 19.0 20.2 21.0 dB vs. Frequency ±50 MHz ±0.01 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.28 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.01 dB Output 1 dB Compression Point (P1dB) 19.0 20.1 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 40.0 dBm Second Harmonic POUT = 0 dBm −59.4 dBc Third Harmonic POUT = 0 dBm −77.3 dBc Noise Figure 2.9 dB FREQUENCY = 2000 MHz Gain 19.5 dB vs. Frequency ±50 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.35 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.04 dB Output 1 dB Compression Point (P1dB) 19.3 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 42.0 dBm Second Harmonic POUT = 0 dBm −53.1 dBc Third Harmonic POUT = 0 dBm −60.7 dBc Noise Figure 3.3 dB FREQUENCY = 2600 MHz Gain 19.2 dB vs. Frequency ±50 MHz ±0.01 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.28 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point (P1dB) 18.7 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 36.5 dBm Second Harmonic POUT = 0 dBm −52.8 dBc Third Harmonic POUT = 0 dBm −67.4 dBc Noise Figure 3.4 dB FREQUENCY = 3500 MHz Gain 19.3 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.37 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.07 dB Output 1 dB Compression Point (P1dB) 17.4 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 31.5 dBm Second Harmonic POUT = 0 dBm −42.9 dBc Third Harmonic POUT = 0 dBm −66.4 dBc Noise Figure 3.8 dB FREQUENCY = 4000 MHz Gain 18.5 dB vs. Frequency ±50 MHz ±0.19 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.73 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.08 dB Output 1 dB Compression Point (P1dB) 15.2 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 28.0 dBm Second Harmonic POUT = 0 dBm −44.1 dBc Third Harmonic POUT = 0 dBm −64.0 dBc Noise Figure 4.2 dB Rev. A | Page 4 of 16 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
