Datasheet ADL5602 (Analog Devices) - 5
Description | 50 MHz TO 4.0 GHz RF/IF Gain Block |
Pages / Page | 16 / 5 — Data Sheet. ADL5602. Parameter. Conditions. Min. Typ. Max. Unit. TYPICAL … |
Revision | A |
File Format / Size | PDF / 310 Kb |
Data Sheet. ADL5602. Parameter. Conditions. Min. Typ. Max. Unit. TYPICAL SCATTERING PARAMETERS (S PARAMETERS). Table 2. Frequency. S11. S21
Data Sheet ADL5602 Parameter Conditions Min Typ Max Unit
POWER INTERFACE VCC Supply Voltage (VCC) 4.5 5 5.5 V Supply Current 89 106 mA vs. Temperature −40°C ≤ TA ≤ +85°C ±3 mA Power Dissipation VCC = 5 V 0.45 W
VCC = 5 V and TA = 25°C, the effects of the test fixture have been de-embedded up to the pins of the device.
Table 2. Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
50 −12.75 +32.81 18.14 +163.00 −25.27 −9.54 −8.96 −145.86 100 −8.98 −7.00 15.77 −179.92 −27.59 +4.56 −7.07 −178.96 150 −10.11 −34.04 17.27 −169.01 −26.11 +16.05 −7.89 +159.89 200 −11.97 −50.46 18.50 −168.73 −24.84 +16.55 −9.33 +147.22 250 −13.85 −62.42 19.21 −171.01 −24.14 +14.79 −10.87 +140.02 300 −15.69 −72.90 19.64 −173.77 −23.70 +12.89 −12.23 +136.16 350 −17.40 −81.30 19.90 −176.45 −23.43 +11.02 −13.56 +134.03 400 −19.17 −88.48 20.07 −178.86 −23.26 +9.65 −14.79 +132.79 450 −20.86 −97.45 20.18 +178.79 −23.14 +8.07 −15.99 +132.72 500 −22.52 −107.32 20.25 +176.86 −23.08 +7.11 −17.02 +133.33 550 −24.32 −112.89 20.32 +174.84 −23.00 +6.15 −18.21 +133.04 600 −26.07 −120.03 20.35 +173.09 −22.97 +5.24 −19.45 +135.06 650 −27.89 −128.79 20.39 +171.35 −22.93 +4.35 −20.73 +136.29 700 −30.79 −133.19 20.42 +169.67 −22.91 +3.72 −22.22 +136.96 750 −34.53 −136.03 20.42 +167.93 −22.91 +2.93 −23.91 +135.39 800 −42.59 −130.76 20.46 +166.48 −22.88 +2.30 −26.35 +136.07 850 −46.49 −2.93 20.47 +164.85 −22.88 +1.67 −29.40 +132.08 900 −34.26 +15.99 20.47 +163.17 −22.86 +0.98 −34.27 +116.48 950 −29.55 +9.83 20.48 +161.77 −22.86 +0.39 −40.86 +41.72 1000 −25.87 +5.52 20.48 +160.25 −22.86 −0.21 −31.44 −10.36 1050 −23.03 +1.85 20.47 +158.65 −22.89 −0.84 −26.19 −18.99 1100 −21.25 +0.10 20.45 +157.18 −22.90 −1.43 −23.27 −22.34 1150 −19.31 −1.89 20.45 +155.50 −22.92 −2.06 −20.70 −22.26 1200 −17.72 −4.09 20.40 +153.93 −22.96 −2.72 −18.67 −24.44 1250 −16.13 −6.53 20.35 +152.44 −23.04 −3.38 −16.92 −24.75 1300 −14.81 −8.71 20.31 +150.88 −23.07 −4.04 −15.44 −25.79 1350 −13.65 −10.01 20.24 +149.35 −23.16 −4.60 −14.14 −25.36 1400 −12.68 −11.33 20.18 +147.91 −23.22 −5.06 −13.12 −25.73 1450 −11.72 −12.65 20.11 +146.40 −23.32 −5.76 −12.04 −25.59 1500 −10.92 −13.56 20.04 +145.13 −23.39 −6.16 −11.20 −25.40 1550 −10.21 −14.37 19.97 +143.86 −23.49 −6.54 −10.49 −25.60 1600 −9.58 −15.37 19.88 +142.58 −23.57 −6.93 −9.77 −25.59 1650 −9.05 −15.74 19.80 +141.40 −23.69 −7.16 −9.21 −25.31 1700 −8.52 −16.73 19.72 +140.23 −23.76 −7.45 −8.66 −25.42 1750 −8.13 −17.13 19.64 +139.13 −23.87 −7.60 −8.26 −25.32 1800 −7.76 −17.59 19.57 +138.12 −23.94 −7.80 −7.91 −24.96 1850 −7.46 −17.76 19.50 +137.16 −24.05 −7.88 −7.56 −24.77 1900 −7.19 −17.92 19.43 +136.25 −24.13 −7.91 −7.35 −24.46 1950 −6.98 −17.84 19.39 +135.31 −24.18 −7.94 −7.13 −23.92 Rev. A | Page 5 of 16 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
