Datasheet ADL5534 (Analog Devices) - 7
Description20 MHz TO 500 MHz IF Amplifier
Pages / Page16 / 7 — Data Sheet. ADL5534. TYPICAL PERFORMANCE CHARACTERISTICS. 23.0. –40°C. …
RevisionB
File Format / SizePDF / 435 Kb
Data Sheet. ADL5534. TYPICAL PERFORMANCE CHARACTERISTICS. 23.0. –40°C. 22.5. GAIN. B) d. 22.0. +85°C. +25°C. N (. OIP3. Bm). 21.5. 3 (. AND G. 21.0. B (. URE
Data Sheet ADL5534 TYPICAL PERFORMANCE CHARACTERISTICS 23.0 –40°C 22.5 GAIN B) d 22.0 +85°C +25°C N ( OIP3 Bm) 21.5 3 ( AND G 21.0 B ( URE
Data Sheet ADL5534 TYPICAL PERFORMANCE CHARACTERISTICS 22 45 23.0 42 20 42 –40°C 22.5 40 18 39 GAIN B) d 22.0 +85°C 38 16 36 +25°C N ( OIP3 Bm) AI 14 33 d 21.5 36 3 ( 12 30 IP Bm) Bm) AND G d d 21.0 +25°C 34 10 27 B ( 3 ( +85°C URE IP 1d O IG P 8 24 B AND O 20.5 32 F P1dB 1d E P IS 6 21 20.0 30 –40°C NO 4 18 19.5 28 2 15 NOISE FIGURE 0 12 19.0 26 0 50 100 150 200 250 300 350 400 450 500
003
006
FREQUENCY (MHz) FREQUENCY (MHz)
06836- 06836- Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. P1dB and OIP3 vs. Frequency and Temperature
21.4 42 21.2 40 190MHz 21.0 70MHz 38 20.8 20.6 36 20.4 500MHz B) 380MHz –40°C d 34 Bm) d 20.2 N ( 3 ( AI 32 IP G 20.0 O 19.8 30 +25°C 19.6 28 +85°C 19.4 26 20MHz 19.2 19.0 24 0 50 100 150 200 250 300 350 400 450 500 –6 –4 –2 0 2 4 6 8 10 12 14 16 18 20
004 007
FREQUENCY (MHz) POUT (dBm)
06836- 06836- Figure 4. Gain vs. Frequency and Temperature Figure 7. OIP3 vs. Output Power and Frequency
–5 5.0 4.5 –10 4.0 ) B ) –15 S11 dB +85°C S (d 3.5 ( E ER R –20 3.0 MET S12 A FIGU R E 2.5 PA –25 OIS S– N +25°C 2.0 S22 –40°C –30 1.5 –35 1.0 20 60 100 140 180 220 260 300 340 380 420 460 500
005
008
06836- 06836- Figure 5. Input Return Loss (S11), Output Return Loss (S22), and Reverse Figure 8. Noise Figure vs. Frequency and Temperature Isolation (S12) vs. Frequency Rev. B | Page 7 of 16 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Using Baluns to Combine Both Amplifiers into a Single Amplifier ADC Driving Application Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
