Datasheet HMC636ST89, 636ST89E (Analog Devices) - 2
DescriptionGaAs pHEMT High Linearity Gain Block, 0.2 - 4.0 GHz
Pages / Page6 / 2 — HMC636ST89 / 636ST89E. GaAs pHEMT HiGH LinEAriTy. Gain Block, 0.2 - 4.0 …
File Format / SizePDF / 397 Kb
HMC636ST89 / 636ST89E. GaAs pHEMT HiGH LinEAriTy. Gain Block, 0.2 - 4.0 GHz. Broadband Gain & return Loss
HMC636ST89 / 636ST89E GaAs pHEMT HiGH LinEAriTy Gain Block, 0.2 - 4.0 GHz Broadband Gain & return Loss
v02.0311
GaAs pHEMT HiGH LinEAriTy Gain Block, 0.2 - 4.0 GHz Broadband Gain & return Loss Gain vs. Temperature
20 16 15 14 10 12 (dB) 5 ) 10 S21 S11 (dB 0 S22 8 IN A -5 G 6 RESPONSE +25C +85C -10 4 -40C 9 -15 2 -20 0 T 0 1 2 3 4 5 6 0 1 2 3 4 FREQUENCY (GHz) FREQUENCY (GHz) m s r -
input return Loss vs. Temperature Output return Loss vs. Temperature
e 0 0 w +25C o ) -5 ) -5 +85C -40C p (dB (dB S S S S LO -10 LO -10 N N R R r & U U T T E E A R R -15 +25C -15 +85C e -40C -20 -20 lin 0 1 2 3 4 0 1 2 3 4 FREQUENCY (GHz) FREQUENCY (GHz) s - r ie
reverse isolation vs. Temperature noise Figure vs. Temperature
0 10 lif 9 ) p -5 +25C 8 +25C +85C (dB ) +85C -40C m N 7 -40C IO (dB T E A -10 6 R LA U O IG 5 IS F E -15 E S 4 R IS E O 3 V N E R -20 2 1 -25 0 0 1 2 3 4 0 1 2 3 4 FREQUENCY (GHz) FREQUENCY (GHz) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
9 - 2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
