Datasheet ADL5570 (Analog Devices) - 4
Description2.3 GHz TO 2.4 GHz WiMAX Power Amplifier
Pages / Page12 / 4 — ADL5570. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
File Format / SizePDF / 356 Kb
ADL5570 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
link to page 4
ADL5570 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress Supply Voltage rating only; functional operation of the device at these or any VCC 5.0 V other conditions above those indicated in the operational VREG 3 V section of this specification is not implied. Exposure to absolute STBY 3 V maximum rating conditions for extended periods may affect MODE 3 V device reliability. RFOUT (Modulated—High Power Mode)1 29 dBm Output Load VSWR 10:1 Operating Temperature Range −40°C to +85°C
ESD CAUTION
Storage Temperature Range −65°C to +150°C Maximum Solder Reflow Temperature 260°C (30 sec) 1 OFDMA carrier, 16 QAM, 10 MHz channel BW, 1024 FFT. Rev. 0 | Page 4 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VCC = 3.5 V ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS BASIC CONNECTIONS Power Supply RF Input Interface RF Output Interface Transmit/Standby Enable VREG Enable MODE High Power/Low Power Enable 64 QAM OFDMA PERFORMANCE POWER-ADDED EFFICIENCY EVALUATION BOARD MEASUREMENT SETUP USING THE ADL5570 EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
