Datasheet ADL5542 (Analog Devices) - 8
Description20 MHz to 6 GHz RF/IF Gain Block
Pages / Page13 / 8 — ADL5542. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. OIP3 (0dBm). …
RevisionC
File Format / SizePDF / 268 Kb
ADL5542. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. OIP3 (0dBm). OIP3 (+25°C). , d. B d. OIP3 (–40°C). OIP3 (+85°C). B (. , N. OIP ,
ADL5542 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS OIP3 (0dBm) OIP3 (+25°C) , d B d OIP3 (–40°C) OIP3 (+85°C) B ( , N OIP ,
VPOS = 5 V and TA = 25°C, unless otherwise noted. C1 = 33 pF, C2 = 33 pF, L1 = 47 nH.
45 50 40 45 ) OIP3 (0dBm) m 40 OIP3 (+25°C) B 35 , d ) 35 B d 30 Bm OIP3 (–40°C) ( d F 30 OIP3 (+85°C) B ( , N 25 d 3 1 25 OIP , 20 GAIN 20 dB AND P 1 3 15 IP , P 15 P1dB (+85°C) P1dB O IN 10 GA 10 P1dB (+25°C) 5 NF
03 06 0
5 P1dB (–40°C)
0 9- 9- 87 87
0
06
0
06
0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0.5 0.9 1.3 1.7 2.1 2.5 2.9 3.3 3.7 4.1 4.5 4.9 5.3 5.7 FREQUENCY (GHz) FREQUENCY (GHz)
Figure 3. Gain, P1dB, OIP3, and Noise Figure vs. Frequency Figure 6. OIP3 and P1dB vs. Frequency and Temperature
20 50 19 45 18 500MHz –40°C 900MHz 17 40 +85°C ) 16 ) B m 35 2.4GHz d B ( d 15 ( 2GHz IN 3 GA 30 14 +25°C OIP 3.5GHz 13 25 12 20
7
11
04 0 00 9- 9- 87 87
10
06
15
06
0.5 0.9 1.3 1.7 2.1 2.5 2.9 3.3 3.7 4.1 4.5 4.9 5.3 5.7 –3 0 3 6 9 12 15 18 FREQUENCY (GHz) POUT (dBm)
Figure 4. Gain vs. Frequency and Temperature Figure 7. OIP3 vs. Output Power (POUT) and Frequency
0 8 –5 S22 7 –10 –15 ) B 6 B) d d –20 E ( 12 ( R U S –25 S12 IG 5 22, +85°C S –30 ISE F 11, O S N 4 +25°C –35 S11 –40 3 –40°C
05
–45
08 0 0 9- 9- 87 87
–50
06
2
06
0 1 2 3 4 5 6 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 FREQUENCY (GHz) FREQUENCY (GHz)
Figure 5. Input Return Loss (S11), Output Return Loss (S22), and Figure 8. Noise Figure vs. Frequency and Temperature Reverse Isolation (S12) vs. Frequency Rev. C | Page 8 of 13 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OPERATING TO 20 MHz BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
