Datasheet ADL5541 (Analog Devices) - 8
Description20 MHz to 6 GHz RF/IF Gain Block
Pages / Page13 / 8 — ADL5541. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. OIP3 (+25°C). …
RevisionB
File Format / SizePDF / 272 Kb
ADL5541. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. OIP3 (+25°C). OIP3 (0dBm). m B. , d. B d. OIP3 (+85°C). OIP3 (–40°C). B (. , N. OIP
ADL5541 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS OIP3 (+25°C) OIP3 (0dBm) m B , d B d OIP3 (+85°C) OIP3 (–40°C) B ( , N OIP
VPOS = 5 V and TA = 25°C, unless otherwise noted. C1 = 33 pF, C2 = 33 pF, L1 = 47 nH.
45 45 OIP3 (+25°C) 40 40 ) OIP3 (0dBm) m B 35 35 , d ) B d 30 Bm 30 OIP3 (+85°C) ( d OIP3 (–40°C) F B ( , N 25 d 25 3 1 OIP P1dB (+85°C) , 20 P1dB 20 dB AND P 1 3 15 IP 15 , P GAIN O IN 10 10 P1dB (–40°C) GA 5 NF
03
5 P1dB (+25°C)
06 0 0 7- 7- 87 87
0
06
0
06
0.5 0.9 1.3 1.7 2.1 2.5 2.9 3.3 3.7 4.1 4.5 4.9 5.3 5.7 0.5 0.9 1.3 1.7 2.1 2.5 2.9 3.3 3.7 4.1 4.5 4.9 5.3 5.7 FREQUENCY (GHz) FREQUENCY (GHz)
Figure 3. Gain, P1dB, OIP3, and Noise Figure vs. Frequency Figure 6. OIP3 and P1dB vs. Frequency and Temperature
16 50 500MHz 45 15 900MHz 40 14 +85°C –40°C 2.4GHz 35 2GHz ) ) B m d B ( d 13 30 IN ( 3 3.5GHz GA OIP 25 12 +25°C 20 11 15
7 04 0 00 7- 7- 87 87
10
06
10
06
0.5 0.9 1.3 1.7 2.1 2.5 2.9 3.3 3.7 4.1 4.5 4.9 5.3 5.7 –5 –3 –1 1 3 5 7 9 11 13 15 FREQUENCY (GHz) POUT (dBm)
Figure 4. Gain vs. Frequency and Temperature Figure 7. OIP3 vs. Output Power (POUT) and Frequency
0 8 –5 S22 7 –10 S11 ) B) –15 B 6 d d ( 12 ( –20 +85°C S S12 URE 5 22, IG –25 F S E +25°C 11, IS S –30 NO 4 –35 –40°C 3 –40
05 0 08 0 7- 7- 87 87
–45
06
2
06
0 1 2 3 4 5 6 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 FREQUENCY (GHz) FREQUENCY (GHz)
Figure 5. Input Return Loss (S11), Output Return Loss (S22), and Figure 8. Noise Figure vs. Frequency and Temperature Reverse Isolation (S12) vs. Frequency Rev. B | Page 8 of 13 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OPERATING TO 20 MHz BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
