Datasheet ADL5530 (Analog Devices)
Description | DC to 1000 MHz IF Gain Block |
Pages / Page | 16 / 1 — DC to 1000 MHz. IF Gain Block. Data Sheet. ADL5530. FEATURES. FUNCTIONAL … |
Revision | C |
File Format / Size | PDF / 1.0 Mb |
DC to 1000 MHz. IF Gain Block. Data Sheet. ADL5530. FEATURES. FUNCTIONAL BLOCK DIAGRAM
DC to 1000 MHz IF Gain Block Data Sheet ADL5530 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 16.5 dB Operation up to 1000 MHz NC 1 8 GND 37 dBm Output Third-Order Intercept (OIP3) IN1 2 7 OUT1 3 dB noise figure NC 3 6 NC Input/output internally matched to 50 Ω Stable temperature and power supply NC 4 5 NC ADL5530
001
3 V or 5 V power supply NC = NO CONNECT
05834-
110 mA power supply current
Figure 1.
APPLICATIONS VCO buffers General purpose Tx/Rx amplification GENERAL DESCRIPTION
The ADL5530 is a broadband, fixed-gain, linear amplifier that The ADL5530 operates with supply voltages of 3 V or 5 V with operates at frequencies up to 1000 MHz. The device can be used a supply current of 110 mA. in a wide variety of wired and wireless devices, including cellular, broadband, CATV, and LMDS/MMDS applications. The ADL5530 is fabricated on a GaAs pHEMPT process. The device is packaged in a 3 mm × 2 mm LFCSP that uses an The ADL5530 provides a gain of 16.5 dB, which is stable over exposed paddle for excellent thermal impedance. It operates frequency, temperature, power supply, and from device to from −40°C to +85°C. A ful y populated evaluation board is device. It achieves an OIP3 of 37 dBm with an output also available. compression point of 21.8 dB and a noise figure of 3 dB. This amplifier is single-ended and internal y matched to 50 Ω with an input return loss of 11 dB. Only input/output ac-coupling capacitors, a power supply decoupling capacitor, and an external inductor are required for operation.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2006–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
