Datasheet ADL5530 (Analog Devices) - 8
DescriptionDC to 1000 MHz IF Gain Block
Pages / Page16 / 8 — ADL5530. Data Sheet. OIP3 (–40°C). 5V (10dBm). OIP3 (+85°C). OIP3 …
RevisionC
ADL5530. Data Sheet. OIP3 (–40°C). 5V (10dBm). OIP3 (+85°C). OIP3 (+25°C). B (. ( 3. ND P. OIP. 3V (5dBm). P1dB (+25°C). P1dB (–40°C)
ADL5530 Data Sheet OIP3 (–40°C) 5V (10dBm) OIP3 (+85°C) OIP3 (+25°C) B ( ( 3 ND P OIP 3V (5dBm) P1dB (+25°C) P1dB (–40°C)
ADL5530 Data Sheet 40 40 OIP3 (–40°C) 38 39 38 36 37 34 5V (10dBm) ) OIP3 (+85°C) 36 OIP3 (+25°C) Bm 32 d ) 35 B ( 30 m d B 34 1 d 28 ( 3 33 ND P 26 OIP A 32 3 3V (5dBm) P1dB (+25°C) IP 24 31 O P1dB (–40°C) 22 30 20 P1dB (+85°C) 29
2 09 0 01
18 28
4- 4- 83 583
16
0
27
05
0 100 200 300 400 500 600 700 800 900 1000 0 100 200 300 400 500 600 700 800 900 1000 FREQUENCY (MHz) FREQUENCY (MHz)
Figure 9. OIP3 and P1dB vs. Frequency and Temperature, VPOS = 5 V Figure 12. OIP3 vs. Frequency and Supply, VPOS = 5 V and 3 V
45 12 11 40 190MHz 10 900MHz ) 9 35 B ) d ( m 380MHz 8 B d 70MHz URE ( 30 3 IG 7 F OIP E 6 IS 25 NO 5 4 5V 20
10 0 13
3 3V
0 4- 4- 83
15
05 583
2
0
0 2 4 6 8 10 12 14 16 18 20 22 24 0 100 200 300 400 500 600 700 800 900 1000 POUT (dBm) FREQUENCY (MHz)
Figure 10. OIP3 vs. Output Power and Frequency, VPOS = 5 V Figure 13. Noise Figure vs. Frequency and Supply, VPOS = 5 V and 3 V
10 140 9 135 130 8 A) 125 B) (m (d 7 5V NT 120 URE IG 6 115 F E CURRE Y IS 3V 5 L 110 P NO UP 105 4 –40°C S +25°C 100 3
1 1 0 14
95
0 4-
+85°C
4- 83
2
05 583
90
0
0 100 200 300 400 500 600 700 800 900 1000 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 FREQUENCY (MHz) TEMPERATURE (°C)
Figure 11. Noise Figure vs. Frequency and Temperature, VPOS = 5 V Figure 14. Supply Current vs. Temperature and Supply, VPOS = 5 V and 3 V Rev. C | Page 8 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
