Datasheet HMC3653LP3BE (Analog Devices) - 3
DescriptionHBT GAIN BLOCK MMIC AMPLIFIER, 7 - 15 GHz
Pages / Page8 / 3 — HMC3653LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 7 - 15 GHz. Psat vs. …
File Format / SizePDF / 643 Kb
HMC3653LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 7 - 15 GHz. Psat vs. Temperature. Output IP3 vs Temperature
HMC3653LP3BE HBT GAIN BLOCK MMIC AMPLIFIER, 7 - 15 GHz Psat vs Temperature Output IP3 vs Temperature
HMC3653LP3BE
v02.0917
HBT GAIN BLOCK MMIC AMPLIFIER, 7 - 15 GHz Psat vs. Temperature Output IP3 vs Temperature
22 35 T m 20 30 s ) 18 25 (dBm) (dBm Psat 16 IP3 20 er - 14 15 w 12 10 po 7 8 9 10 11 12 13 14 15 7 8 9 10 11 12 13 14 15 FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -40 C +25 C +85 C -40 C r & A e
Phase Noise @ Pin=0 dBm Power Compression @ 8 GHz
lin -100 20 -110 (%) 15 s - -120 z) PAE /H -130 dBc 10 ( (dB), -140 ISE O GAIN N 5 E -150 S A H P -160 (dBm), 0 plifier -170 Pout m -180 -5 10 102 103 104 105 106 107 108 -20 -16 -12 -8 -4 0 4 8 A OFFSET(Hz) INPUT POWER (dBm) 8 GHz 12 GHz 15 GHz Pout Gain PAE
Power Compression @ 11 GHz Power Compression @ 14 GHz
20 20 (%) (%) 15 15 PAE PAE 10 (dB), 10 (dB), GAIN GAIN 5 5 (dBm), (dBm), 0 0 Pout Pout -5 -5 -20 -17 -14 -11 -8 -5 -2 1 4 7 -20 -15 -10 -5 0 5 INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Second Harmonics vs. Pout Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Temperature @ Pout = 18 dBm Power Dissipation Power Compression @ 10 GHz Psat vs. Vdd P1dB vs. Vdd Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Frequency Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain & Return Loss Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
