Datasheet HMC311ST89, 311ST89E (Analog Devices)
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 6 GHz
Pages / Page6 / 1 — HMC311ST89 / 311ST89E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 6 GHz. …
File Format / SizePDF / 893 Kb
HMC311ST89 / 311ST89E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 6 GHz. Features. Typical Applications. Functional Diagram
Datasheet HMC311ST89, 311ST89E Analog Devices
v04.0517
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 6 GHz Features Typical Applications
The HMC311ST89(E) is ideal for: P1dB Output Power: +15.5 dBm T • Cel ular / PCS / 3G Output IP3: +31.5 dBm M • Fixed Wireless & WLAN Gain: 16 dB • CATV & Cable Modem 50 Ohm I/O’s K - S • Microwave Radio Industry Standard SOT89 Package C Included in the HMC-DK001 Designer’s Kit LO
IN B The HMC311ST89(E) is a GaAs InGaP Heterojunc- A tion Bipolar Transistor (HBT) Gain Block MMIC SMT DC to 6 GHz amplifier. Packaged in an industry standard SOT89E, the amplifier can be used as either a cascadable 50 Ohm gain stage or to drive the LO of R & G HMC mixers with up to +16.5 dBm output power. The E HMC311ST89(E) offers 16 dB of gain and an output IV IP3 of +31.5 dBm while requiring only 54 mA from a R +5V supply. The Darlington feedback pair used results in reduced sensitivity to normal process variations and yields excel ent gain stability over temperature R - D while requiring a minimal number of external bias IE components. ILF
Electrical Specifications, Vs= 5V, Rbias= 22 Ohm, T = +25° C
P
A
M Parameter Min. Typ. Max. Units A DC - 1.0 GHz 14.0 16.0 dB Gain 1.0 - 4.0 GHz 13.0 15.0 dB 4.0 - 6.0 GHz 12.5 14.5 dB DC - 2.0 GHz 0.004 0.007 dB/ °C Gain Variation Over Temperature 2.0 - 4.0 GHz 0.007 0.012 dB/ °C 4.0 - 6.0 GHz 0.012 0.016 dB/ °C DC - 2.0 GHz 8 dB Return Loss Input / Output 2.0 - 5.0 GHz 7 dB 5.0 - 6.0 GHz 8 dB Reverse Isolation DC - 6 GHz 20 dB DC - 2.0 GHz 13.5 15.5 dBm Output Power for 1 dB Compression (P1dB) 2.0 - 4.0 GHz 12.0 15.0 dBm 4.0 - 6.0 GHz 10.0 13.0 dBm DC - 1.0 GHz 31.5 dBm 1.0 - 2.0 GHz 30 dBm Output Third Order Intercept (IP3) 2.0 - 4.0 GHz 27 dBm 4.0 - 6.0 GHz 24 dBm DC - 4 GHz 4.5 Noise Figure dB 4.0 - 6.0 GHz 5 Supply Current (Icq) 55 74 mA Note: Data taken with broadband bias tee on device output. F In o fo r p rma rtiic o e n f , d urni e s lhiv e e d r b y, a y An n al d t og o p Devi lca e c s e o is b r eld ie e v r e s: A d to n b a e lao c g D curat e e v a ince d r s el , I iabn lec . ., O How n eve T er, e n c o hn Folog r pry W ice ay , d , P eliv .O er . B y, a o n x 9 d t 10 o p6 l , N ac or e o w rd o erosd, M : An A 0 alo 20 g D 6 ev2 i - c 9 e 1 s 0 , I6 nc., responsibility is assumed by Analog Devices for it Ph s us oen , n eo: 78 r for a 1n-3 y in 2fri9n-g4 e 7 m 0 en 0 • O ts of patrd enter o s or ontlhienr rights of third parties that may result from its use. Specifications subject to change without notice. No e at w On w e T w ec .a hnnoall o o g g.c y W o a m y, P.O. Box 9106, Norwood, MA 02062-9106
1
license is granted by implication or otherwise under an A y p p at p enlica t o t r p iao ten S nt ri u gh p t p s o or f A tn: P alo ho g D n ev e ic : 1 es. -80 P0h-oAnN e A : 7 LO 81- G 32-D 9-4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
