Datasheet HMC311SC70, 311SC70E (Analog Devices)
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 8 GHz
Pages / Page6 / 1 — HMC311SC70 / 311SC70E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 8 GHz. …
File Format / SizePDF / 962 Kb
HMC311SC70 / 311SC70E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 8 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC311SC70, 311SC70E Analog Devices
v05.0517
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 8 GHz Typical Applications Features
The HMC311SC70(E) is ideal for: P1dB Output Power: +15 dBm T • Cel ular / PCS / 3G Output IP3: +30 dBm M • WiBro / WiMAX / 4G Gain: 15 dB • Fixed Wireless & WLAN Cascadable, 50 Ohm I/O’s S - S • CATV & Cable Modem Single Supply: +5V R • Microwave Radio & Test Equipment Industry Standard SC70 Package IE LIF
P The HMC311SC70(E) is a GaAs InGaP Heterojunction M Bipolar Transistor (HBT) Gain Block MMIC SMT DC to 8 GHz amplifier. Packaged in an industry K A standard SC70, the amplifier can be used as either C a cascadable 50 Ohm gain stage or to drive the LO port of HMC mixers with up to +15 dBm output power. LO The HMC311SC70(E) offers 15 dB of gain and an output IP3 of +30 dBm while requiring only 54 mA from a +5V supply. The Darlington topology results in IN B reduced sensitivity to normal process variations, and A yields excellent gain stability over temperature while requiring a minimal number of external bias components. R & G E IV
Electrical Specifications, Vs= 5V, Rbias= 22 Ohm, T = +25° C A
R Parameter Min. Typ. Max. Units D DC - 1.0 GHz 14.0 15.0 dB 1.0 - 4.0 GHz 13.0 15.0 dB Gain 4.0 - 6.0 GHz 12.5 14.5 dB 6.0 - 8.0 GHz 11.0 13.0 dB DC - 1.0 GHz 0.004 0.007 dB/ °C 1.0 - 4.0 GHz 0.007 0.012 Gain Variation Over Temperature dB/ °C 4.0 - 6.0 GHz 0.012 0.016 dB/ °C 6.0 - 8.0 GHz 0.018 0.022 Return Loss Input / Output DC - 8.0 GHz 15 dB Reverse Isolation DC - 8.0 GHz 18 dB DC - 2.0 GHz 13.5 15.5 dBm 2.0 - 4.0 GHz 12.0 15.0 dBm Output Power for 1 dB Compression (P1dB) 4.0 - 6.0 GHz 10.0 13.0 dBm 6.0 - 8.0 GHz 8.0 11.0 dBm DC - 2.0 GHz 30 dBm Output Third Order Intercept (IP3) 2.0 - 6.0 GHz 27 dBm 6.0 - 8.0 GHz 24 dBm Noise Figure DC - 8.0 GHz 5 dB Supply Current (Icq) 55 74 mA Note: Data taken with broadband bias tee on device output. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Typical Performance Characteristics Broadband Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Reverse Isolation vs. Temperature Noise Figure vs. Temperature P1dB vs. Temperature Psat vs. Temperature Power Compression @ 1 GHz Power Compression @ 6 GHz Output IP3 vs. Temperature Gain, Power, IP3 & Supply Current vs. Supply Voltage @ 1 GHz Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Application Circuit Recommended Component Values Evaluation PCB List of Materials for Evaluation PCB
