Datasheet HT16D33A/HT16D33B (Holtek) - 2
ManufacturerHoltek
Description16×16 Constant Current LED Driver
Pages / Page86 / 2 — HT16D33A/HT16D33B. 16×16 Constant Current LED Driver. Table of Contents. …
Revision1.10
File Format / SizePDF / 3.0 Mb
HT16D33A/HT16D33B. 16×16 Constant Current LED Driver. Table of Contents. Features .. 4 Applications ... 4
HT16D33A/HT16D33B 16×16 Constant Current LED Driver Table of Contents Features . 4 Applications .. 4
link to page 4 link to page 4 link to page 5 link to page 5 link to page 5 link to page 6 link to page 8 link to page 8 link to page 9 link to page 9 link to page 10 link to page 11 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 17 link to page 17 link to page 18 link to page 18 link to page 28 link to page 29 link to page 32 link to page 34 link to page 34 link to page 36 link to page 36 link to page 38 link to page 39 link to page 40 link to page 41
HT16D33A/HT16D33B HT16D33A/HT16D33B 16×16 Constant Current LED Driver 16×16 Constant Current LED Driver Table of Contents Features .. 4 Applications ... 4 General Description ... 5 Selection Table ... 5 Block Diagram .. 5 Pin Assignment .. 6 Pin Description .. 8 Approximate Internal Connections .. 8 Absolute Maximum Ratings .. 9 D.C. Characteristics ... 9 A.C. Characteristics ... 10
A.C. Characteristics – SPI 3-wire Serial Bus ... 11 A.C. Characteristics – I2C Serial Bus ... 11
Timing Diagrams .. 12
SPI 3-wire Serial Bus Timing ..12 I2C Bus Timing ..12 Power on Reset Timing ..12
Functional Description .. 13
Power-on Reset ...13 LED Driver ..13 System Oscillator ...13 Driver Outputs ..13 Address Pointer ..13
Open/Short Detection Function .. 14
Over Temperature Protection ...17 Constant Current Output ..17 Load Supply Voltage – LED_VDD ...18 Display Data RAM – DDRAM ...18 PWM Data Width Timing ..28 Fade Data RAM ...29 LED On/Off Control RAM Data ..32
Command Description ..34
Command Table ...34 Software Reset ...36 RAM Page Address Set ...36 Picture Display Address ...38 Movie Display Start Address ..39 Movie Playing Length ...40 Movie Cycle Time ...41 Rev. 1.10 2 April 11, 2019 Rev. 1.10 3 April 11, 2019 Document Outline Features Applications General Description Selection Table Block Diagram Pin Assignment Pin Description Approximate Internal Connections Absolute Maximum Ratings D.C. Characteristics A.C. Characteristics A.C. Characteristics – SPI 3-wire Serial Bus A.C. Characteristics – I2C Serial Bus Timing Diagrams SPI 3-wire Serial Bus Timing I2C Bus Timing Power on Reset Timing Functional Description Power-on Reset LED Driver System Oscillator Driver Outputs Address Pointer Open/Short Detection Function Over Temperature Protection Constant Current Output Load Supply Voltage – LED_VDD Display Data RAM – DDRAM PWM Data WidthTiming Fade Data RAM LED On/Off Control RAM Data Command Description Command Table Software Reset RAM Page Address Set Picture Display Address Movie Display Start Address Movie Playing Length Movie Cycle Time Movie Page Delay Time Last Page Set Picture Scrolling Control Display Mode Configuration Mode Fade Function Control Global Fade Time Cascade Mode System Control Constant Current Ratio Brightness Control Mode Control Blanking Control Voltage Setting Read Open Detection Data Read Short Detection Data Read Register Status Read Movie Frame Status Read Movie Loop Status Read Function Flag SPI 3-wire Serial Interface Write Operation Read Operation I2C Serial Interface Data Validity START and STOP Conditions Byte Format Acknowledge Slave Addressing Write Operation Read Operation Power Supply Sequence Operation Flow Charts Application Circuits LED Matrix Circuit RGB LED Matrix Circuit Single LED IC Application Cascade Function Cascade Control Flow Package Information 24-pin SSOP-EP (150mil) Outline Dimensions 28-pin SSOP (150mil) Outline Dimensions SAW Type 32-pin QFN (4mm×4mm×0.75mm) Outline Dimensions
