Datasheet HT16D33A/HT16D33B (Holtek) - 3
ManufacturerHoltek
Description16×16 Constant Current LED Driver
Pages / Page86 / 3 — HT16D33A/HT16D33B. 16×16 Constant Current LED Driver. SPI 3-wire Serial …
Revision1.10
File Format / SizePDF / 3.0 Mb
HT16D33A/HT16D33B. 16×16 Constant Current LED Driver. SPI 3-wire Serial Interface ... 56. I2C Serial Interface ... 60
HT16D33A/HT16D33B 16×16 Constant Current LED Driver SPI 3-wire Serial Interface .. 56 I2C Serial Interface .. 60
link to page 41 link to page 42 link to page 43 link to page 44 link to page 44 link to page 44 link to page 46 link to page 47 link to page 47 link to page 47 link to page 48 link to page 49 link to page 50 link to page 51 link to page 52 link to page 53 link to page 53 link to page 54 link to page 55 link to page 56 link to page 56 link to page 57 link to page 60 link to page 60 link to page 60 link to page 60 link to page 61 link to page 61 link to page 62 link to page 63 link to page 66 link to page 67 link to page 68 link to page 68 link to page 71 link to page 79 link to page 79 link to page 81 link to page 82 link to page 83 link to page 84 link to page 85
HT16D33A/HT16D33B HT16D33A/HT16D33B 16×16 Constant Current LED Driver 16×16 Constant Current LED Driver
Movie Page Delay Time ...41 Last Page Set ..42 Picture Scrolling Control ..43 Display Mode ...44 Configuration Mode ...44 Fade Function Control ..44 Global Fade Time ...46 Cascade Mode ...47 System Control ...47 Constant Current Ratio ..47 Brightness Control ..48 Mode Control ..49 Blanking Control Voltage Setting ..50 Read Open Detection Data ..51 Read Short Detection Data ..52 Read Register Status ...53 Read Movie Frame Status ...53 Read Movie Loop Status ..54 Read Function Flag ..55
Write Operation ..56 Read Operation ..57
Data Validity ...60 START and STOP Conditions ..60 Byte Format ..60 Acknowledge ..61 Slave Addressing ...61 Write Operation ..62 Read Operation ..63
Power Supply Sequence ... 66 Operation Flow Charts .. 67 Application Circuits ... 68
LED Matrix Circuit ..68 RGB LED Matrix Circuit ...71 Single LED IC Application ..79 Cascade Function ..79 Cascade Control Flow ..81
Package Information ... 82
24-pin SSOP-EP (150mil) Outline Dimensions ..83 28-pin SSOP (150mil) Outline Dimensions ..84 SAW Type 32-pin QFN (4mm×4mm×0.75mm) Outline Dimensions ..85 Rev. 1.10 2 April 11, 2019 Rev. 1.10 3 April 11, 2019 Document Outline Features Applications General Description Selection Table Block Diagram Pin Assignment Pin Description Approximate Internal Connections Absolute Maximum Ratings D.C. Characteristics A.C. Characteristics A.C. Characteristics – SPI 3-wire Serial Bus A.C. Characteristics – I2C Serial Bus Timing Diagrams SPI 3-wire Serial Bus Timing I2C Bus Timing Power on Reset Timing Functional Description Power-on Reset LED Driver System Oscillator Driver Outputs Address Pointer Open/Short Detection Function Over Temperature Protection Constant Current Output Load Supply Voltage – LED_VDD Display Data RAM – DDRAM PWM Data WidthTiming Fade Data RAM LED On/Off Control RAM Data Command Description Command Table Software Reset RAM Page Address Set Picture Display Address Movie Display Start Address Movie Playing Length Movie Cycle Time Movie Page Delay Time Last Page Set Picture Scrolling Control Display Mode Configuration Mode Fade Function Control Global Fade Time Cascade Mode System Control Constant Current Ratio Brightness Control Mode Control Blanking Control Voltage Setting Read Open Detection Data Read Short Detection Data Read Register Status Read Movie Frame Status Read Movie Loop Status Read Function Flag SPI 3-wire Serial Interface Write Operation Read Operation I2C Serial Interface Data Validity START and STOP Conditions Byte Format Acknowledge Slave Addressing Write Operation Read Operation Power Supply Sequence Operation Flow Charts Application Circuits LED Matrix Circuit RGB LED Matrix Circuit Single LED IC Application Cascade Function Cascade Control Flow Package Information 24-pin SSOP-EP (150mil) Outline Dimensions 28-pin SSOP (150mil) Outline Dimensions SAW Type 32-pin QFN (4mm×4mm×0.75mm) Outline Dimensions
