WSBS8518...34 www.vishay.com Vishay Dale Power Metal Strip® Shunt Resistor,Low TCR (Down to < ± 10 ppm/°C),Very Low Value (100 μ, 500 μ, and 1000 μ)FEATURES • High power to resistor size ratio • Proprietary processing technique produces extremely low resistance values • All welded construction • Solid metal nickel-chrome alloy resistive element with unique design for low TCR (down to ± 10 ppm/°C) • Very low inductance (< 5 nH) • Low thermal EMF (as low as < 1.25 μV/°C) • PATENT(S): www.vishay.com/patents DESIGN SUPPORT TOOLS click logo to get started • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 Models Available STANDARD ELECTRICAL SPECIFICATIONSPOWER RATINGRESISTANCE VALUERESISTANCE VALUESWEIGHTGLOBAL TOLERANCESIZEPRANGECURRENTLY AVAILABLE (1)(typical)MODEL70 °C± %Wg WSBS8518...34 8518 36 5, 10 100μ to 1000μ 100μ 36.0 WSBS8518...34 8518 25 5, 10 100μ to 1000μ 500μ 33.4 WSBS8518...34 8518 20 5, 10 100μ to 1000μ 1000μ 31.3 Note (1) Other values may be available, contact factory TECHNICAL SPECIFICATIONSPARAMETERUNITRESISTOR CHARACTERISTICS ± 65 for 100 μ Temperature coefficient ppm/°C ± 10 for 500 μ ± 25 for 1000 μ Operating temperature range °C -65 to +170 Thermal EMF μV/°C < 1.25 Inductance nH < 5 Maximum current rating A (P/R)1/2 GLOBAL PART NUMBER INFORMATIONGLOBAL PART NUMBERING: WSBS8518L5000JT34 (WSBS8518…34, 0.0005, ± 5 %, tray pack)WSBS8518L5000JT34 GLOBAL MODEL RESISTANCE VALUE TOLERANCE CODE PACKAGING CODE SPECIAL WSBS8518L = m J = ± 5 % K = bulk pack 34 = low TCR L1000 = 0.000100 K = ± 10 % T = tray pack L5000 = 0.000500 1L000 = 0.001000 PATENT(S): www.vishay.com/patents This Vishay product is protected by one or more United States and International patents. Revision: 09-Mar-17 1 Document Number: 30354 For technical questions, contact: ww2cresistors@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
