Datasheet R1525x-Y for Industrial Applications (Ricoh) - 4
ManufacturerRicoh
DescriptionHigh Noise Immunity Low Supply Current 42V Input 200mA Voltage Regulator
Pages / Page29 / 4 — R1525x-Y. R1525S (HSOP-6J) Pin Description. Pin No. Pin Name. …
R1525x-Y. R1525S (HSOP-6J) Pin Description. Pin No. Pin Name. Description. R1525S (HSOP-8E) Pin Description
R1525x-Y R1525S (HSOP-6J) Pin Description Pin No Pin Name Description R1525S (HSOP-8E) Pin Description
R1525
R1525x-Y
NO. EY-520-190109
R1525S (HSOP-6J) Pin Description Pin No. Pin Name Description
1 VOUT Output Pin 2 GND(1) Ground Pin 3 CE Chip Enable Pin (Active-high) 4 GND(1) Ground Pin 5 GND(1) Ground Pin 6 VDD Input Pin
R1525S (HSOP-8E) Pin Description Pin No. Pin Name Description
1 VOUT Output Pin 2 NC No Connection 3 NC No Connection 4 CE Chip Enable Pin (Active-high) 5 GND Ground Pin 6 NC No Connection 7 NC No Connection 8 VDD Input Pin
Pin Equivalent Circuit Diagrams
Driver CE VOUT
VOUT Pin Equivalent Circuit Diagram CE Pin Equivalent Circuit Diagram
(1) The GND pins are connected to each other on the board. 4
