Datasheet SM8S-Q (Bourns) - 7
ManufacturerBourns
Description6600 W TVS Diodes - VWM 16~43 V - DO-218 Package - AEC-Q101 Compliant
Pages / Page8 / 7 — CDDFN5-0504N. SM8S-Q T. - TVS/Steering. ransient V. Diode Array. oltage …
File Format / SizePDF / 523 Kb
CDDFN5-0504N. SM8S-Q T. - TVS/Steering. ransient V. Diode Array. oltage Suppressor Diode Series. Packaging Information. Item. Symbol
CDDFN5-0504N SM8S-Q T - TVS/Steering ransient V Diode Array oltage Suppressor Diode Series Packaging Information Item Symbol
The product will be dispensed in tape and reel format (see diagram below). P0 P E T 1 d Index Hole 120 ° F D2 W B D1 D P A C Trailer Device Leader ... ... ... ... W1 End ... ... ... ... Start DIMENSIONS: MM (INCHES) 10 pitches (min.) 10 pitches (min.) Devices are packed in accordance with EIA 481 standard specifications shown here. Direction of Feed
Item Symbol SM8S-Q Series
Carrier Width A 10.77 ± 0.20 (0.424 ± 0.008) Carrier Length B 16.33 ± 0.20 (0.643 ± 0.008) Carrier Depth C 6.02 ± 0.20 (0.237 ± 0.008) Sprocket Hole d 1.50 + 0.10 / - 0.00 (0.059 + 0.004 / - 0.00) Reel Outside Diameter D 330 ± 2.0 (12.992 ± 0.079) Reel Inner Diameter D 60.0 1 (2.362) MIN. Feed Hole Diameter D 13.0 + 0.50 / - 0.20 2 (0.512 + 0.020 / - 0.008) Sprocket Hole Position E 1.75 ± 0.10 (0.069 ± 0.004) Punch Hole Position F 11.5 ± 0.10 (0.453 ± 0.004) Punch Hole Pitch P 16.0 ± 0.10 (0.63 ± 0.004) Sprocket Hole Pitch P 4.00 ± 0.10 0 (0.157 ± 0.004) Embossment Center P 2.00 ± 0.10 1 (0.079 ± 0.004) Overall Tape Thickness T 12 (0.472) MAX. Tape Width W 24.0 ± 0.30 (0.945 ± 0.012) Reel Width W 30.4 1 (1.197) MAX. Quantity per Reel -- 750 02/19 Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
