Datasheet TMC4671 (TRINAMIC) - 3
Manufacturer | TRINAMIC |
Description | Dedicated Motion Controller for 2-/3-Phase PMSM |
Pages / Page | 159 / 3 — 5 Safety Functions. 6 Register Map. 7 Pinning. 138. 8 TMC4671 Pin Table. … |
File Format / Size | PDF / 5.1 Mb |
5 Safety Functions. 6 Register Map. 7 Pinning. 138. 8 TMC4671 Pin Table. 140. 9 Electrical Characteristics. 144. 10 Sample Circuits. 146
link to page 38 link to page 39 link to page 40 link to page 41 link to page 42 link to page 42 link to page 43 link to page 43 link to page 43 link to page 44 link to page 45 link to page 46 link to page 46 link to page 47 link to page 47 link to page 47 link to page 48 link to page 49 link to page 49 link to page 50 link to page 52 link to page 52 link to page 53 link to page 53 link to page 53 link to page 53 link to page 54 link to page 54 link to page 54 link to page 55 link to page 56 link to page 57 link to page 57 link to page 61 link to page 138 link to page 140 link to page 144 link to page 144 link to page 144 link to page 144 link to page 145 link to page 146 link to page 146 link to page 146 link to page 146 link to page 147 link to page 147 link to page 149 TMC4671 Datasheet • IC Version V1.00 | Document Revision V1.06 • 2019-Feb-06 3 / 159 4.7.7 Digital Hall Sensors together with Incremental Encoder . 38 4.7.8 Analog Hall and Analog Encoder Interface (SinCos of 0° 90° or 0° 120° 240°) . 39 4.7.9 Analog Position Decoder (SinCos of 0°90° or 0°120°240°) . 40 4.7.10 Encoder Initialization Support . 41 4.7.11 Velocity Measurement . 42 4.7.12 Reference Switches . 42 4.8 FOC23 Engine . 43 4.8.1 PI Controllers . 43 4.8.2 PI Controller Calculations - Classic Structure . 43 4.8.3 PI Controller Calculations - Advanced Structure . 44 4.8.4 PI Controller - Clipping . 45 4.8.5 PI Flux & PI Torque Controller . 46 4.8.6 PI Velocity Controller . 46 4.8.7 P Position Controller . 47 4.8.8 Inner FOC Control Loop - Flux & Torque . 47 4.8.9 FOC Transformations and PI(D) for control of Flux & Torque . 47 4.8.10 Motion Modes . 48 4.8.11 Brake Chopper . 49 4.9 Filtering and Feed-Forward Control . 49 4.9.1 Biquad Filters . 50 4.9.2 Standard Velocity Filter . 52 4.9.3 Feed-Forward Control Structure . 52 4.10 PWM Engine . 53 4.10.1 PWM Polarities . 53 4.10.2 PWM Frequency . 53 4.10.3 PWM Resolution . 53 4.10.4 PWM Modes . 54 4.10.5 Break-Before-Make (BBM) . 54 4.10.6 Space Vector PWM (SVPWM) . 54
5 Safety Functions 55
5.1 Watchdog . 56
6 Register Map 57
6.1 Register Map Overview . 57 6.2 Register Map Full . 61
7 Pinning 138 8 TMC4671 Pin Table 140 9 Electrical Characteristics 144
9.1 Absolute Maximum Ratings . 144 9.2 Electrical Characteristics . 144 9.2.1 Operational Range . 144 9.2.2 DC Characteristics . 145
10 Sample Circuits 146
10.1 Supply Pins . 146 10.2 Clock and Reset Circuitry . 146 10.3 Digital Encoder, Hall Sensor Interface and Reference Switches . 146 10.4 Analog Frontend . 147 10.5 Phase Current Measurement . 147 10.6 Power Stage Interface . 149 ©2019 TRINAMIC Motion Control GmbH & Co. KG, Hamburg, Germany Terms of delivery and rights to technical change reserved. Download newest version at www.trinamic.com Document Outline 1 Order Codes 2 Functional Summary 3 FOC Basics 3.1 Why FOC? 3.2 What is FOC? 3.3 Why FOC as pure Hardware Solution? 3.4 How does FOC work? 3.5 What is Required for FOC? 3.5.1 Coordinate Transformations - Clarke, Park, iClarke, iPark 3.5.2 Measurement of Stator Coil Currents 3.5.3 Stator Coil Currents I_U, I_V, I_W and Association to Terminal Voltages U_U, U_V, U_W 3.5.4 Measurement of Rotor Angle 3.5.5 Measured Rotor Angle vs. Magnetic Axis of Rotor vs. Magnetic Axis of Stator 3.5.6 Knowledge of Relevant Motor Parameters and Position Sensor (Encoder) Parameters 3.5.7 Proportional Integral (PI) Controllers for Closed Loop Current Control 3.5.8 Pulse Width Modulation (PWM) and Space Vector Pulse Width Modulation (SVPWM) 3.5.9 Orientations, Models of Motors, and Coordinate Transformations 4 Functional Description 4.1 Functional Blocks 4.2 Communication Interfaces 4.2.1 SPI Slave User Interface 4.2.2 TRINAMIC Real-Time Monitoring Interface (SPI Master) 4.2.3 UART Interface 4.2.4 Step/Direction Interface 4.2.5 Single Pin Interface 4.3 Numerical Representation, Electrical Angle, Mechanical Angle, and Pole Pairs 4.3.1 Numerical Representation 4.3.2 N_POLE_PAIRS, PHI_E, PHI_M 4.3.3 Numerical Representation of Angles PHI 4.4 ADC Engine 4.4.1 ADC Group A and ADC Group B 4.4.2 Internal Delta Sigma ADCs 4.4.3 External Delta Sigma ADCs 4.5 Delta Sigma Configuration and Timing Configuration 4.5.1 Internal Delta Sigma Modulators - Mapping of V_RAW to ADC_RAW 4.5.2 External Delta Sigma Modulator Interface 4.5.3 ADC Configuration - MDAC 4.6 Analog Signal Conditioning 4.6.1 FOC3 - Stator Coil Currents I_U, I_V, I_W and Association to Terminal Voltages U_U, U_V, U_W 4.6.2 Stator Coil Currents I_X, I_Y and Association to Terminal Voltages U_X, U_Y 4.6.3 ADC Selector & ADC Scaler w/ Offset Correction 4.7 Encoder Engine 4.7.1 Open-Loop Encoder 4.7.2 Incremental ABN Encoder 4.7.3 Secondary Incremental ABN Encoder 4.7.4 Digital Hall Sensor Interface with optional Interim Position Interpolation 4.7.5 Digital Hall Sensor - Interim Position Interpolation 4.7.6 Digital Hall Sensors - Masking and Filtering 4.7.7 Digital Hall Sensors together with Incremental Encoder 4.7.8 Analog Hall and Analog Encoder Interface (SinCos of 0° 90° or 0° 120° 240°) 4.7.9 Analog Position Decoder (SinCos of 0°90° or 0°120°240°) 4.7.10 Encoder Initialization Support 4.7.11 Velocity Measurement 4.7.12 Reference Switches 4.8 FOC23 Engine 4.8.1 PI Controllers 4.8.2 PI Controller Calculations - Classic Structure 4.8.3 PI Controller Calculations - Advanced Structure 4.8.4 PI Controller - Clipping 4.8.5 PI Flux & PI Torque Controller 4.8.6 PI Velocity Controller 4.8.7 P Position Controller 4.8.8 Inner FOC Control Loop - Flux & Torque 4.8.9 FOC Transformations and PI(D) for control of Flux & Torque 4.8.10 Motion Modes 4.8.11 Brake Chopper 4.9 Filtering and Feed-Forward Control 4.9.1 Biquad Filters 4.9.2 Standard Velocity Filter 4.9.3 Feed-Forward Control Structure 4.10 PWM Engine 4.10.1 PWM Polarities 4.10.2 PWM Frequency 4.10.3 PWM Resolution 4.10.4 PWM Modes 4.10.5 Break-Before-Make (BBM) 4.10.6 Space Vector PWM (SVPWM) 5 Safety Functions 5.1 Watchdog 6 Register Map 6.1 Register Map Overview 6.2 Register Map Full 7 Pinning 8 TMC4671 Pin Table 9 Electrical Characteristics 9.1 Absolute Maximum Ratings 9.2 Electrical Characteristics 9.2.1 Operational Range 9.2.2 DC Characteristics 10 Sample Circuits 10.1 Supply Pins 10.2 Clock and Reset Circuitry 10.3 Digital Encoder, Hall Sensor Interface and Reference Switches 10.4 Analog Frontend 10.5 Phase Current Measurement 10.6 Power Stage Interface 11 Setup Guidelines 12 Package Dimensions 13 Supplemental Directives 13.1 Producer Information 13.2 Copyright 13.3 Trademark Designations and Symbols 13.4 Target User 13.5 Disclaimer: Life Support Systems 13.6 Disclaimer: Intended Use 13.7 Collateral Documents & Tools 14 Errata 15 Figures Index 16 Tables Index 17 Revision History 17.1 IC Revision 17.2 Document Revision
