Datasheet UT69RH051 (Aeroflex) - 5
ManufacturerAeroflex
DescriptionRadiation-Hardened MicroController
Pages / Page20 / 5 — 8 BYTES. INDIRECT. ACCESS. ONLY. SCRATCH. PAD AREA. DIRECT OR. BIT. …
8 BYTES. INDIRECT. ACCESS. ONLY. SCRATCH. PAD AREA. DIRECT OR. BIT. ADDRESSABLE. SEGMENT. REGISTER. BANKS
8 BYTES INDIRECT ACCESS ONLY SCRATCH PAD AREA DIRECT OR BIT ADDRESSABLE SEGMENT REGISTER BANKS
8 BYTES F8 FF F0 F7 INDIRECT
ACCESS
ONLY
88 8F SCRATCH 80 87 PAD AREA 78 7F 70 77
38 3F DIRECT OR 30 37 INDIRECT 28 2F ACCESS BIT ADDRESSABLE 20 27 SEGMENT 18 1F 10 17 REGISTER BANKS 08 0F 00 07 Figure 3. Internal Data Memory Organization 2.1.3 Reset
While RST is high, PSEN and the port pins are pulled high; ALE The reset input is the RST pin. To reset, hold the RST pin high is pulled low. All SFRs are reset to their reset values as shown for a minimum of 24 oscillator periods while the oscillator is in table 3. The internal Data Memory content is indeterminate. running. The CPU generates an internal reset from the external signal. The port pins are driven to the reset state as soon as a valid The processor will begin operation one machine cycle after the high is detected on the RST pin. RST line is brought low. A memory access occurs immediately after the RST line is brought low, but the data is not brought into the processor. The memory access repeats on the next machine cycle and actual processing begins at that time. 5
