Datasheet AL3353 (Diodes) - 4
ManufacturerDiodes
DescriptionHigh Performance Boost LED Controller
Pages / Page15 / 4 — AL3353. Electrical Characteristics. Symbol. Parameter. Conditions. Min. …
File Format / SizePDF / 368 Kb
AL3353. Electrical Characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. Unit. Supply Voltage. Under Voltage Lockout. Soft Start
AL3353 Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit Supply Voltage Under Voltage Lockout Soft Start
(VIN = 12V, VPWM = 5V, @TA = +25°C, unless otherwise specified.) (Note 6)
VIN Input Voltage – 9.0 – 40 V IOP Operating Supply Current VIN = 12V, VPWM = 5V, no load – 2 3 mA ISHDN Shutdown Supply Current PWM low > 50mS, Sleep Mode – 130 180 µA
Under Voltage Lockout T
VUVLO Input UVLO Threshold VIN Rising 7.8 8.3 8.8 V VHYS Input UVLO Hysteresis – – 800 – mV
UC Soft Start
ISS_SLOP Soft Start Slope – – 22 – mV/ms
OD Error Amplifier R
Reference voltage at
P
VFB Feedback Reference Voltage 394 400 406 mV non-inverting input
W
Am Open Loop Voltage Gain – – 70 – dB Gm Transconductance of EA – – 100 – µA/V
NE
ISOURCE Output Source Current – – 30 – µA ISINK Output Sink Current – – 60 – µA
PWM to Analog Dimming Control
– PWM Duty – 0 – 100 % VPWM_H – 2.5 – – V PWM Logic Input for Analog Dimming VPWM_L – – – 1.2 V
Protection Threshold
VOVP_OV Output Over Voltage Threshold Voltage – 1.9 2.0 2.1 V Normal operation – 250 – mV VOVP_UVLO OVP UVLO Threshold Voltage System startup – 150 – mV VCS_OCP Over Current Threshold Voltage Duty = 90% 425 500 575 mV VCS_HIGH CS High Protection Threshold Diode or Inductor short 1.1 1.2 1.3 V VCMP_HIGH COMP High Protection Threshold FB short to GND 2.9 3.2 3.5 V TOTP Over Temperature Threshold – – +160 – °C
Gate Driver
fOSC Oscillator Frequency – 110 120 130 kHz DMAX Max. Duty Cycle – 93 95 97 % VGATE Gate Pin Output Voltage VIN =24V – 13 – V tRISE Rising Time – 40 – ns 1nF load tFALL Falling Time – 20 – ns Note: 6. These parameters, although guaranteed by design, are not 100% tested in production. AL3353 4 of 15 February 2019 Document number: DS41487 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Applications Features
