Datasheet RP517x (Ricoh)
ManufacturerRicoh
Description0.3V Low Output Voltage Low Quiescent Current 300mA Buck DC/DC Converter
Pages / Page29 / 1 — RP517x Series. 0.3 V Ultra-low Output Voltage 300 mA Buck DC/DC …
RP517x Series. 0.3 V Ultra-low Output Voltage 300 mA Buck DC/DC Converter. OVERVIEW. KEY BENEFITS. KEY SPECIFICATIONS
Datasheet RP517x Ricoh
RP517x Series 0.3 V Ultra-low Output Voltage 300 mA Buck DC/DC Converter
No.EA-519-190325
OVERVIEW
RP517x is a low-voltage resistance buck DC/DC converter featuring ultra-low 0.3 μA quiescent current and 0.3 V output voltage. Suitable for wearable and IoT devices which require long-life batteries and downsizing.
KEY BENEFITS
● Ultra-low consumption current (IQ: 0.3 μA) with the VFM control for DC/DC (switching frequency: 1 MHz max.) ● Suitable for low power devices due to its ultra-low output voltage range from 0.3 V to 1.2 V ● Suitable for coin batteries and USB ports due to its wide input range from 1.8 V to 5.5 V ● Selectable 3 packages: WLCSP, DFN and SOT. Suitable for IC cards due to WLCSP’s thickness of 0.4 mm and less.
KEY SPECIFICATIONS TYPICAL PERFORMANCE CHARACTERISTICS
• RP517x051x, Ta=25°C Output current: 300 mA • Output Voltage Range: 0.3 V to 1.2 V (Settable in 0.1 V step) • Output Voltage Accuracy: ±18 mV • Built-in Driver On-resistance (VIN = 3.6 V): Typ. PMOS 0.15 Ω, NMOS 0.15 Ω (RP517Z) • Standby Current: 0.01 µA
TYPICAL APPLICATIONS SELECTION GUIDE
VIN VOUT VIN LX Product Name Package Quantity per Reel L RP517x 2.2 µH RP517Zxx1$-TR-F WLCSP-8-P1 5,000 pcs C VOUT IN COUT 10 µF 22 µF RP517Kxx1$-TR DFN(PLP)2527-10 5,000 pcs CE GND RP517Hxx1$-T1-FE SOT-89-5 1,000 pcs xx: The set output voltage (VSET) Fixed Output Voltage Type:
PACKAGES (unit: mm)
0.3 V (03) to 1.2 V (12) in 0.1 V step $: The auto-discharge option
Version Auto-discharge Function VSET C
No 0.3 V to 1.2 V WLCSP-8-P1 DFN(PLP)2527-10 SOT-89-5
D
Yes 1.45 x 1.48 x 0.36 2.7 x 2.5 x 0.6 4.5 x 4.35 x 1.5 (Under development) (Under development)
• Wearable equipment such as SmartWatch, SmartBand and Health monitoring • Li-ion battery-used equipment, Coin cell-used equipment • Low power RF such as Bluetooth® Low Energy, Zigbee, WiSun and ANT • Low power CPU, Memory, Sensor device and Energy harvester 1
