Datasheet TMPM4G Group(1) (Toshiba) - 2
Manufacturer | Toshiba |
Description | TXZ4 |
Pages / Page | 132 / 2 — TMPM4G Group(1). Datasheet |
File Format / Size | PDF / 1.7 Mb |
TMPM4G Group(1) Datasheet
● Consumer Electronics Control Circuit (CEC): 1 channel ● 8-bit DA converter (DAC): 2 channels ● 12-bit AD converter (ADC): 16 to 24 channel inputs ‒ Sample and hold circuit ‒ Conversion time: 1.0 µs @fADCLK = 60 MHz ● Advanced Programmable Motor Control Circuit (A-PMD): 1 channel ‒ 3 phase PWM output, Synchronized with 12-bit ADC ‒ Emergency stop function by external inputs (EMG0 pin and OVV0 pin) ● 32-bit Timer Event Counter (T32A) ‒ 28 channels as 16-bit Timers:14 channels as 32-bit Timers ‒ Interval Timer, event counter, input capture, phase difference input, PPG output, Sync Start,Trigger Start ● Interval Sensor Detection circuit (ISD): 3 units ‒ 4 inputs per unit ‒ Sampling 12 inputs at maximum simultaneously in Unit synchronous mode ‒ Low speed oscil ator (32.768 kHz) and 32-bit timer output can be used as sampling clock ● Long Term Timer (LTTMR): 1 channel ‒ Interval time of 0.1μs to 6553.5μs can be set ● Real-time Clock (RTC): 1 channel ● Clock Selective Watchdog Timer (SIWDT): 1 channel ‒ Clocks other than the system clock can be selected. ‒ Clear window, interrupts and reset outputs ● Remote Control Signal Preprocessor (RMC): 1 to 2channels ● Supports boundary scan(BSC) 2018-11-12 2 / 132 Rev.4.1 Document Outline General Description Applications Features Products Lists Categorized by Functions 1. Block Diagram 2. Pin Assignment 2.1. LQFP176 2.2. LQFP144 2.3. LQFP128 2.4. LQFP100 2.5. VFBGA177 2.6. VFBGA145 3. Memory Map 3.1. List of Memory Sizes 4. Pin Description 4.1. Functional Pin Name and Function 4.1.1. Peripheral Function Pins 4.1.2. Debug Pins 4.1.3. Control Pins 4.1.4. Power Supply Pins 4.2. Functional Pin and Port Assignment (Pin Number) 4.3. Ports 4.3.1. Port Specifications Table 5. Functional Description and Operation Description 5.1. Reference Manuals 5.2. Processor Core 5.2.1. Core Information 5.2.2. Configurable Options 5.3. Clock Control and Operation Mode (CG) 5.4. Flash Memory (Code FLASH, Data FLASH) 5.5. Oscillation Circuit 5.6. Trimming Circuit (TRM) 5.7. Oscillation Frequency Detector (OFD) 5.8. Voltage Detection Circuit (LVD) 5.9. Digital Noise Filter Circuit (DNF) 5.10. Debug Interface (DEBUG) 5.11. Non Break Debug Interface(NBDIF) 5.12. Interval Sensor Detection Circuit(ISD) 5.13. DMA Controller 5.13.1. Multi-Function DMA Controller (MDMAC) 5.13.2. High Speed DMA Controller (HDMAC) 5.14. External Bus Interface (EBIF) 5.15. Serial Memory Interface (SMIF) 5.16. Asynchronous Serial Communication Circuit 5.16.1. Asynchronous Serial Communication Circuit (UART) 5.16.2. Full Universal Asynchronous Receiver Transmitter Circuit (FUART) 5.17. Serial Peripheral Interface (TSPI) 5.18. I2C Interface (I2C) 5.19. Consumer Electronics Control Circuit (CEC) 5.20. 8-bit Digital to Analog Converter (DAC) 5.21. 12-bit Analog to Digital Converter (ADC) 5.22. Advanced Programmable Motor Control Circuit (A-PMD) 5.23. 32-bit Timer Event Counter (T32A) 5.24. Long Term Timer (LTTMR) 5.25. Real Time Clock (RTC) 5.26. Clock Selective Watchdog Timer (SIWDT) 5.27. Remote Control Signal Preprocessor (RMC) 5.28. Boundary-scan (BSC) 6. Equivalent Circuit 6.1. Port 6.2. Analog Power pin 6.3. Control Pin 6.4. Clock control 7. Electrical Characteristics 7.1. Absolute Maximum Ratings 7.2. DC Electrical Characteristics (1/2) 7.3. DC Electrical Characteristics (2/2) (Consumption current) 7.4. 12-bit AD Converter Characteristics 7.5. 8-bit DA Converter Characteristics 7.6. Characteristics of Internal processing at RESET 7.7. Characteristics of Power on Reset 7.8. Characteristics of Voltage Detection Circuit 7.9. AC Electrical Characteristics 7.9.1. Serial Peripheral Interface (TSPI) 7.9.1.1. AC Measurement Conditions 7.9.1.2. AC Electrical Characteristics 7.9.2. I2C Interface (I2C) 7.9.3. 32-bit Timer Event Counter (T32A) 7.9.4. External Bus Interface(EBIF) 7.9.4.3. AC Electrical Characteristics (EEXBCLK asynchronous Separate Mode) 7.9.4.4. AC Electrical Characteristics (EEXBCLK asynchronous multiplex bus mode) 7.9.4.5. AC Electrical Characteristics (EEXBCLK synchronous separate bus mode / multiplex bus mode) 7.9.5. Serial Memory Interface (SMIF) 7.9.5.1. AC Measurement Conditions 7.9.6. External Interrupt 7.9.6.1. AC Measurement Conditions 7.9.6.2. AC Electrical Characteristics 7.9.7. Trigger Input (TRGINx) 7.9.7.1. AC Measurement Conditions 7.9.7.2. AC Electrical Characteristics 7.9.8. Debug Communication 7.9.8.1. AC Measurement Conditions 7.9.8.2. SWD Interface 7.9.8.3. JTAG Interface 7.9.8.4. ETM Trace 7.9.8.6. Noise Filter Characteristics 7.9.9. External Clock Input 7.9.9.1. AC Measurement Conditions 7.10. Flash Memory Characteristics 7.10.1. Code Flash 7.10.2. Data Flash 7.10.3. Chip Erase 7.11. Regulator 7.12. Oscillation Circuit 7.12.1. Internal Oscillator 7.12.2. External Oscillator 7.12.3. Ceramic Oscillator 7.12.4. Crystal Oscillator 7.12.5. Precautions for designing printed circuit board 8. Package Dimensions 8.1. P-LQFP176-2020-0.40-002 8.2. P-LQFP144-2020-0.50-002 8.3. P-LQFP128-1414-0.40-001 8.4. P-LQFP100-1414-0.50-002 8.5. P-VFBGA177-1313-0.80-001 8.6. P-VFBGA145-1212-0.80-001 9. Precautions 10. Revision History Part Naming Conventions
