Datasheet L5965 (STMicroelectronics) - 3
Manufacturer | STMicroelectronics |
Description | Multiple power management for automotive vision and radar systems |
Pages / Page | 85 / 3 — L5965. Functional block diagram. 1.2. Figure 2. Functional block diagram. … |
File Format / Size | PDF / 1.3 Mb |
L5965. Functional block diagram. 1.2. Figure 2. Functional block diagram. DS12567. Rev 2. page 3/85
L5965 Functional block diagram 1.2 Functional block diagram Figure 2. Functional block diagram
Application example with BUCK2 as main buck. VBAT 1 VBAT 1 EXTSUP EXTSUP SGND - 4.6 V REFERENCE + VREG AGND bandgap1 diagnostic VREG 2 DGND Frequency BST1 VBUCK processor SYNCIN BUCK1 GH1 SYNCOUT VBUCK1 PH1 GL 1 bandgap3 PGND1 REF REF VREF sensep diagnostic sensen VSLDO VSLDO VREG1_S COMP1 LDO Current control Output control LDO LDO diagnostic VBAT 2 VBAT 1 diagnostic BST2 3.3 V BUCK2 PH2 VBUCK2 diagnostic PGND2 & Safety Output /loop VREG2_S management control bandgap 2 monitors , logic VBUCK2 FAULT diagnostic COMP2 MCU VBUCK2 VIN 3 interface 3.3 V BST3 BUCK3 TJ clusters PH3 VBUCK3 ADC VBAT 1 PGND3 Output /loop control VREG3_S WDI MCU Watchdog & diagnostic VBUCK2 MCU RESET_B reset VBUCK2 VIN 4 BST4 3.3 V BUCK4 VBAT 1 PH4 VBUCK4 WKUP Input control PGND4 Debug Output /loop control VREG4_S CSN MCU diagnostic VBUCK2 CLK MCU PH5 VBOOST 3.3 V MCU DI SPI BOOST PGND5 VBUCK2 MCU DO Output/ VBOOST_ S control diagnostic GADG1005181537PS
DS12567
Rev 2 page 3/85
Document Outline 1 Overview 1.1 Simplified block diagram 1.2 Functional block diagram 2 Pins description 3 Electrical specifications 3.1 Absolute maximum ratings & operating voltage 3.2 Thermal data 3.2.1 Thermal resistance 3.2.2 Thermal warning and protection 3.3 Electrical characteristics 3.3.1 Electrical characteristic curves 4 Functional description 4.1 Programming by OTP 4.2 Voltage regulators and features description 4.2.1 VREG 4.2.2 Pre regulator BUCK1 4.2.3 Pre regulator BUCK2 4.2.4 Post regulator BUCK3 4.2.5 Post regulator BUCK4 4.2.6 BOOST 4.2.7 LDO 4.2.8 VREF 4.2.9 ADC 4.2.10 Wake up pin (WKUP) 4.2.11 Synchronizing pin (SYNC in/out) 4.2.12 Reset and Fault 4.2.13 Configurable watchdog and reset 4.2.14 Under-Voltage, Over-Voltage and Power-Good 4.2.15 Temperature control and VBATx voltage through internal ADC 4.2.16 Maximum Duty Cycle and Refresh Mode for Buck 4.2.17 Frequency-Hopping Spread Spectrum 5 SPI format and register mapping 5.1 SPI frame CRC generator 5.2 SPI registers mapping 5.2.1 SPI REG BUCK1 5.2.2 SPI REG BUCK2 5.2.3 SPI REG WD_REC_EN 5.2.4 SPI REG BUCK4 5.2.5 SPI REG BOOST VREF 5.2.6 SPI REG BUCK EN 5.2.7 SPI REG WD 5.2.8 SPI REG BUCK STAT1 5.2.9 SPI REG BUCK STAT2 5.2.10 SPI REG Fault Table PWUP 5.2.11 SPI REG ADC TH1 5.2.12 SPI REG ADC TH2 5.2.13 SPI REG ADC TH3 5.2.14 SPI REG ADC TH4 5.2.15 SPI REG ADC TH5 5.2.16 SPI REG ADC TH6 5.2.17 SPI REG ADC TH7 5.2.18 SPI REG ADC VBAT1 5.2.19 SPI REG ADC VBAT2 5.2.20 SPI REG OT Warning 5.2.21 SPI Fault STAT 5.2.22 SPI Silicon Version 5.2.23 SPI Device Identification 6 Device operating mode 6.1 Shutdown mode 6.2 Standby mode 6.3 INIT mode 6.4 REC mode 6.5 RAMPUP MAIN and SEC_UP 6.6 ACTIVE mode 6.7 OTP program mode 6.8 OTP bit mapping and register configuration 6.9 OTP (SAF) registers 6.9.1 SAF_REG_OP 6.9.2 SAF_REG_CFG 6.9.3 SAF_REG_DI 6.9.4 SAF_REG_D0_Bit_Ts 6.9.5 SAF_REG_STAT 6.10 Power down phase 6.11 Power up programming 7 Functional safety requirements 7.1 Functions and safety mechanism related to safety requirements 7.2 System safety mechanism 8 Application information 8.1 External components calculation 8.1.1 BUCK1 controller 8.1.1.1 RSENSE 8.1.1.2 BUCK1 output inductor 8.1.1.3 BUCK1 output capacitor 8.1.1.4 BUCK1 bootstrap capacitor 8.1.1.5 BUCK1 compensation network 8.1.2 BUCK2 controller 8.1.2.1 BUCK2 output inductor 8.1.2.2 BUCK2 output capacitor 8.1.2.3 BUCK2 compensation network 8.1.3 BUCK3, BUCK4 8.1.3.1 Output inductor and capacitor 8.1.3.2 Bootstrap capacitor for BUCK3 and BUCK4 8.1.3.3 Input capacitor 8.1.4 BOOST 8.1.4.1 BOOST output inductor 8.1.4.2 BOOST output capacitor 8.1.4.3 BOOST compensation network 8.1.4.4 Output diode for the BOOST converter 8.1.4.5 Input capacitor selection 8.2 PCB Layout example (BUCK1 as main regulator) 9 Package information 9.1 VFQFPN-48 (7x7x1.0 mm - opt. D) package information 9.2 VFQFPN-48 (7x7x1.0) marking information Revision history
