Datasheet H1012NL, H1086NL, HX1148NL (Pulse Electronics)
ManufacturerPulse Electronics
Description10/100 Base-T Single Port Transformer Modules With 1:1 Transmit Turns Ratios
Pages / Page3 / 1 — Insertion. Differential to Common. Crosstalk. Loss. Return Loss. Mode …
File Format / SizePDF / 716 Kb
Insertion. Differential to Common. Crosstalk. Loss. Return Loss. Mode Rejection. RoHS. Hipot. Compliant
Datasheet H1012NL, H1086NL, HX1148NL Pulse Electronics
10/100 Base-T Single Port Transformer Modules With 1:1 Transmit Turns Ratios RoHS peak reflow temperature rating: 245�C Compatible with Broadcom, Intel, Microtel, National Semiconductor, ICS, and TDK Transceivers Meets IEEE 802.3 specification Electrical Specifications @ 25°C - Operating Temperature 0°C to 70°C
Insertion Differential to Common Crosstalk Loss Return Loss Mode Rejection
(dB TYP)
RoHS
(dB MAX) (dB MIN @ 100 Ω) (dB MIN)
Hipot Compliant
(Vrms MIN)
Part Number 3 0.1-100 MHz 1-30 MHz 40 MHz 50 MHz 60-80 MHz 30 MHz 60 MHz 100 MHz 30 MHz 60 MHz 100 MHz H1012NL 4c
-1.0 -20 -20 -18 -14 -42 -36 -33 -50 -40 -40 1500
H1086NL 4c
-1.0 -22 -20 -18 -12 -45 -40 -35 -50 -40 -40 1500
HX1148NL 1, 4c
-1.5 -18 -13.5 -11.5 -10 -42 -37 -33 -50 -40 -40 1500
Notes: 1. HX = Operating
temperature: -40 + 85 C.
2. Unless
specified, operating temperature is 0� to 70� C.
4. MSL
= Moisture Sensitivity Level: a= 1, b = 2, C = 3, d = 4
3. When
ordering Tape & Reel packaging, add a “T” suffix to the end of the part number, e.g. H1012NLT.
Mechanical H1012NL, H1086NL, HX1148NL Weight
..3.0 grams
Dimensions:
Inches Unless otherwise specified, all tolerances are .010 ± mm 0,25 USA 858 674 8100 Germany 49 7032 7806 0 Singapore 65 6287 8998 Shanghai 86 21 62787060 China 86 755 33966678 Taiwan 886 3 4356768 1 H303.BB (02/19)
