Datasheet SBR8M100P5Q (Diodes)
ManufacturerDiodes
Description8A Sbr Super Barrier Rectifier
Pages / Page6 / 1 — SBR8M100P5Q. Green. 8A SBR. SUPER BARRIER RECTIFIER. PowerDI5. Product …
File Format / SizePDF / 493 Kb
SBR8M100P5Q. Green. 8A SBR. SUPER BARRIER RECTIFIER. PowerDI5. Product Summary. Features and Benefits. RRM (V). IO (A). VF(MAX) (V)
Datasheet SBR8M100P5Q Diodes
SBR8M100P5Q Green 8A SBR SUPER BARRIER RECTIFIER PowerDI5 Product Summary
(@ TA = +25°C)
Features and Benefits V RRM (V) IO (A) VF(MAX) (V) IR(MAX) (µA)
Low Forward Voltage Drop 100 8 0.88 2 Excellent High Temperature Stability ® Patented Super Barrier Rectifier SBR Technology Soft, Fast Switching Capability
Description and Applications Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
This Super Barrier Rectifier (SBR) diode has been designed to meet
Halogen and Antimony Free. “Green” Device (Note 3)
the stringent requirements of Automotive Application. It is ideally
Qualified to AEC-Q101 Standards for High Reliability
suited to such as:
PPAP Capable (Note 4)
Polarity Protection Diode
Mechanical Data
Re-Circulating Diode ® Switching Diode Case: PowerDI 5 Blocking Diode Case Material: Molded Plastic, “Green” Molding Compound. UL DC-DC Converter Flammability Classification Rating 94V-0 AC-DC Converter Moisture Sensitivity: Level 1 per J-STD-020 Terminals: Finish – Matte Tin Annealed over Copper Leadframe. Solderable per MIL-STD-202, Method 208 Terminal Connections: See Diagram Below Weight: 0.093 grams (Approximate) PowerDI5
LEFT PIN BOTTOM SIDE RIGHT PIN HEAT SINK Note: Pins Left & Right must be electrically connected at the printed circuit board.
Top View Bottom View
Ordering Information
(Note 5)
Part Number Compliance Case Packaging
SBR8M100P5Q-13 Automotive PowerDI5 5000/Tape & Reel SBR8M100P5Q-13D (Note 6) Automotive PowerDI5 5000/Tape & Reel Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. All applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. Automotive products are AEC-Q101 qualified and are PPAP capable. Refer to https://www.diodes.com/quality/. 5. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/. 6. Suffix -13D is designated for 12mm tape width.
Marking Information S8M100
S8M100 = Product Type Marking Code = Manufacturers’ Code Marking YYWW = Date Code Marking YY = Last Two Digits of Year (ex: 18 for 2018) WW = Week Code (01 to 53)
YYWWK
K = Factory Designator SBR and PowerDI are registered trademarks of Diodes Incorporated. SBR8M100P5Q 1 of 6 December 2018 Document number: DS37626 Rev. 5 - 2
www.diodes.com
© Diodes Incorporated
