Datasheet Addendum XFC236156.250000I (IDT)
ManufacturerIDT
Description150fs Small Package Quartz-based PLL Oscillator
Pages / Page2 / 1 — 156.250000MHz Crystal. XFC236156.250000I. Oscillator. Datasheet Addendum. …
Revision20181207
File Format / SizePDF / 34 Kb
156.250000MHz Crystal. XFC236156.250000I. Oscillator. Datasheet Addendum. General Configuration. Parameter. Value. Pin Assignments
Datasheet Addendum XFC236156.250000I IDT, Revision: 20181207
156.250000MHz Crystal XFC236156.250000I Oscillator Datasheet Addendum General Configuration Parameter Value
Device Version XF version (150fs typical phase jitter) Package 2.5 × 2.0 mm Output Frequency 156.250000MHz Frequency Stability ±25ppm VDD Voltage 3.3V Output Type CML Output Enable/Disable (E/D) Position Pin 5 Temperature Grade -40°C to +85°C
Pin Assignments Number Name Description
5 E/D Enable/Disable 1 (0 = output disable). 1, 2, 3, 4, 6 NC No connect. 10, 12, EPAD GND Connect to ground. 8 OUT1 Output. 9 OUT1b Complementary Output. 7, 11 VDD Supply voltage. 1 Pulled high internally. ©2018 Integrated Device Technology, Inc. 1 December 6, 2018 Document Outline General Configuration Pin Assignments Revision History
