Datasheet MA12070 (Infineon) - 6
ManufacturerInfineon
Description2x80W ultra power efficient, fully integrated audio amplifier IC with analog input
Pages / Page86 / 6 — Pin No. Name. Type1. Description. Type1:. www.infineon.com
Revision01_00
Pin No Name Type1 Description Type1: www.infineon.com
Pin No. Name Type1 Description 39
OUT1B O Audio power output 1B
40
CF1BP P Connect to external flying capacitor positive terminal for amplifier channel 1B
41
PVDD P Power supply for power amplifiers
42
43
CF1AP P Connect to external flying capacitor positive terminal for amplifier channel 1A
44
OUT1A O Audio power output 1A
45
46
CF1AN P Connect to external flying capacitor negative terminal for amplifier channel 1A
47
PVSS P Power ground for internal power amplifiers
48
49
NC P Internally connected to DVDD
50
MSEL1 I SE/BTL/PBTL configuration select 1
51
MSEL0 I SE/BTL/PBTL configuration select 0
52
CGD1N P Connect to external decoupling capacitor negative terminal for internal gate driver power supply 1
53
CGD1P P Connect to external decoupling capacitor positive terminal for internal gate driver power supply 1
54
VGDC P Internally generated virtual ground voltage for digital core. Should be decoupled to DVDD.
55
DVDD P Power supply for internal digital circuitry and charge pumps
56
CDC P Connect to external decoupling capacitor for digital core internal power supply
57
CFDCP P Connect to external flying capacitor positive terminal for internal digital core power supply
58
CFDCN P Connect to external flying capacitor negative terminal for internal digital core power supply
59
DVSS P Power ground for internal digital circuitry
60
CGD0P P Connect to external decoupling capacitor positive terminal for internal gate driver power supply 0
61
CGD0N P Connect to external decoupling capacitor negative terminal for internal gate driver power supply 0
62
CFGDP P Connect to external flying capacitor negative terminal for internal gate driver power supplies
63
CFGDN P Connect to external flying capacitor positive terminal for internal gate driver power supplies
64
Type1:
P = Power; I = Input; O = Output; IO = Input or Output Datasheet Please read the Important Notice and Warnings at the end of this document V 1.0
www.infineon.com
page 6 of 86 2018-07-17
