Datasheet ADUM3123 (Analog Devices)
Description | Isolated Precision Gate Driver, 4 A Output |
Pages / Page | 15 / 1 — Isolated Precision Gate Driver,. 4.0 A Output. Data Sheet. ADuM3123. … |
File Format / Size | PDF / 493 Kb |
Isolated Precision Gate Driver,. 4.0 A Output. Data Sheet. ADuM3123. FEATURES. GENERAL DESCRIPTION
Isolated Precision Gate Driver, 4.0 A Output Data Sheet ADuM3123 FEATURES GENERAL DESCRIPTION 4.0 A output short-circuit pulsed current
The ADuM31231 is a 4.0 A isolated, single channel driver that
Isolated working voltage
employs Analog Devices, Inc., iCoupler® technology to provide
Secondary side to input side: 537 V
precision isolation. The ADuM3123 provides 3000 V rms
High frequency operation: 1 MHz maximum
isolation in the narrow-body, 8-lead SOIC package. Combining
3.3 V to 5 V input logic
high speed CMOS and monolithic transformer technology,
4.5 V to 18 V output drive
these isolation components provide outstanding performance
Undervoltage lockout (UVLO): 2.8 V VDD1
characteristics superior to alternatives such as the combination
Precise timing characteristics
of pulse transformers and gate drivers.
64 ns maximum isolator and driver propagation delay
The ADuM3123 operates with an input supply ranging from
Complementary metal oxide semiconductor (CMOS) input
3.0 V to 5.5 V, providing compatibility with lower voltage
logic levels
systems. In comparison to gate drivers employing high voltage
High common-mode transient immunity: >25 kV/μs
level translation methodologies, the ADuM3123 offers the
High junction temperature operation: 125°C
benefit of true, galvanic isolation between the input and the
Default low output
output. The output can continuously operate up to 380 V rms
Safety and regulatory approvals (pending)
relative to the input.
UL recognition per UL 1577 3000 V rms for 1 minute SOIC long package
As a result, the ADuM3123 provides reliable control over the
CSA Component Acceptance Notice 5A
switching characteristics of IGBT/MOSFET configurations over
VDE certificate of conformity (pending)
a wide range of positive and negative switching voltages.
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 Maximum working insulation voltage (VIORM) = 560 V peak Narrow body, 8-lead SOIC APPLICATIONS Switching power supplies Isolated gate bipolar transistors (IGBT)/MOSFET gate drives Industrial inverters FUNCTIONAL BLOCK DIAGRAM ADuM3123 VDD1 1 8 VDD2 V 2 ENCODE DECODE I 7 VO DISABLE 3 6 NIC GND1 4 5 GND2
1 -00 4
NIC = NOT INTERNALLY CONNECTED
57 12 Figure 1. 1 Protected by U.S. Patents 5,952,849; 6,873,065; 7,075,239. Other patents pending.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety Related Specifications Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Printed Circuit Board (PCB) Layout Propagation Delay Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide
