Datasheet ADUM7234 (Analog Devices) - 3
DescriptionIsolated Precision Half-Bridge Driver, 4 A Output
Pages / Page12 / 3 — Data Sheet. ADuM7234. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. …
File Format / SizePDF / 215 Kb
Data Sheet. ADuM7234. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Test Conditions/. Parameter Symbol. Min. Typ. Max. Unit. Comments
Data Sheet ADuM7234 SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Test Conditions/ Parameter Symbol Min Typ Max Unit Comments
link to page 5 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3
All voltages are relative to their respective grounds. 4.5 V ≤ VDD1 ≤ 5.5 V, 12 V ≤ VDDA ≤ 18 V, and 12 V ≤ VDDB ≤ 18 V. All minimum/ maximum specifications apply over the entire recommended operating range, unless otherwise noted. All typical specifications are at TA = 25°C, VDD1 = 5 V, VDDA = 15 V, and VDDB = 15 V.
Table 1. Test Conditions/ Parameter Symbol Min Typ Max Unit Comments
DC SPECIFICATIONS Input Supply Current, Quiescent IDDI(Q) 1.0 2.2 mA Output Supply Current A or Output Supply IDDA(Q), IDDB(Q) 1.5 3.2 mA Current B, Quiescent Input Supply Current, 2 Mbps IDDI(2) 1.4 3.0 mA Output Supply Current A or Output Supply IDDA(2), IDDB(2) 22 30 mA CL = 1000 pF Current B, 2 Mbps Input Currents IIA, IIB, IDISABLE −10 +0.01 +10 μA 0 V ≤ VIA, VIB, VDISABLE ≤ VDD1 Logic High Input Threshold VIH 0.7 × VDD1 V Logic Low Input Threshold VIL 0.3 × VDD1 V Logic High Output Voltages VOAH, VOBH VDDA − 0.15, VDDA, VDDB V IOA, IOB = −20 mA VDDB − 0.15 Logic Low Output Voltages VOAL, VOBL 0.15 V IOA, IOB = 20 mA Undervoltage Lockout, VDDA or VDDB Supply UVLO Positive-Going Threshold VDDBUV+ 8.0 8.9 9.8 V Negative-Going Threshold VDDBUV− 7.4 8.2 9.0 V Hysteresis VDDBUVH 0.3 0.7 V Output Short-Circuit Pulsed Current1 IOA(SC), IOB(SC) 2.0 4.0 A SWITCHING SPECIFICATIONS CL = 1000 pF Minimum Pulse Width2 PW 100 ns Maximum Switching Frequency3 2 Mbps Propagation Delay4 tPHL, tPLH 130 160 200 ns Change vs. Temperature 130 ps/°C Pulse Width Distortion, |tPLH − tPHL| PWD 14 ns Channel-to-Channel Matching, 11 ns Rising or Falling Edges5 Channel-to-Channel Matching, 25 ns Rising vs. Falling Edges6 Part-to-Part Matching, Rising or Falling 55 ns Input tR = 3 ns Edges7 Part-to-Part Matching, Rising vs. Falling 63 ns Input tR = 3 ns Edges8 Output Rise/Fall Time (10% to 90%) tR/tF 8 14 30 ns 1 Short-circuit duration less than 1 sec. Average power must conform to the limit shown in the Absolute Maximum Ratings section. 2 The minimum pulse width is the shortest pulse width at which the specified timing parameters are guaranteed. 3 The maximum switching frequency is the maximum signal frequency at which the specified timing parameters are guaranteed. 4 tPHL propagation delay is measured from the 50% level of the falling edge of the VIx signal to the 50% level of the falling edge of the VOx signal. tPLH propagation delay is measured from the 50% level of the rising edge of the VIx signal to the 50% level of the rising edge of the VOx signal. 5 Channel-to-channel matching, rising or falling edges, is the magnitude of the propagation delay difference between two channels of the same part when the inputs are either both rising or falling edges. The supply voltages and the loads on each channel are equal. 6 Channel-to-channel matching, rising vs. falling edges, is the magnitude of the propagation delay difference between two channels of the same part when one input is a rising edge and the other input is a falling edge. The supply voltages and loads on each channel are equal. 7 Part-to-part matching, rising or falling edges, is the magnitude of the propagation delay difference between the same channels of two different parts when the inputs are either both rising or falling edges. The supply voltages, temperatures, and loads of each part are equal. 8 Part-to-part matching, rising vs. falling edges, is the magnitude of the propagation delay difference between the same channels of two different parts when one input is a rising edge and the other input is a falling edge. The supply voltages, temperatures, and loads of each part are equal. Rev. B | Page 3 of 12 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Insulation and Safety-Related Specifications Recommended Operating Conditions Regulatory Information Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Common-Mode Transient Immunity Insulation Lifetime Outline Dimensions Ordering Guide
