Datasheet FDN335N (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionN-Channel 2.5V Specified PowerTrench™ MOSFET 20V, 1.7A, 70mΩ
Pages / Page5 / 2 — FDN335N. Electrical Characteristics. Symbol. Parameter. Test Conditions. …
Revision3
File Format / SizePDF / 203 Kb
FDN335N. Electrical Characteristics. Symbol. Parameter. Test Conditions. Min. Typ. Max. Units. Off Characteristics. On Characteristics
FDN335N Electrical Characteristics Symbol Parameter Test Conditions Min Typ Max Units Off Characteristics On Characteristics
T = 25°C unless otherwise noted A
BVDSS Drain-Source Breakdown Voltage VGS = 0 V, ID = 250 µA 20 V ∆BVDSS Breakdown Voltage Temperature ID = 250 µA,Referenced to 25°C 14 mV/°C ∆TJ Coefficient IDSS Zero Gate Voltage Drain Current VDS = 16 V, VGS = 0 V 1 µA IGSSF Gate-Body Leakage Current, VGS = 8 V, VDS = 0 V 100 nA Forward IGSSR Gate-Body Leakage Current, VGS = -8 V, VDS = 0 V -100 nA Reverse
On Characteristics
(Note 2) VGS(th) Gate Threshold Voltage VDS = VGS, ID = 250 µA 0.4 0.9 1.5 V ∆VGS(th) Gate Threshold Voltage ID = 250 µA,Referenced to 25°C -3 mV/°C ∆TJ Temperature Coefficient RDS(ON) Static Drain-Source VGS = 4.5 V, ID = 1.7 A 0.055 0.070 Ω On-Resistance VGS = 4.5 V, ID = 1.7 A,TJ = 125°C 0.079 0.120 VGS = 2.5 V, ID = 1.5 A 0.078 0.100 ID(on) On-State Drain Current VGS = 4.5 V, VDS = 5 V 8 A gFS Forward Transconductance VDS = 5 V, ID = 1.5 A 7 S
Dynamic Characteristics
Ciss Input Capacitance VDS = 10 V, VGS = 0 V, 310 pF C f = 1.0 MHz oss Output Capacitance 80 pF Crss Reverse Transfer Capacitance 40 pF
Switching Characteristics
(Note 2) td(on) Turn-On Delay Time VDD = 10 V, ID = 1 A, 5 15 ns t VGS = 4.5 V, RGEN = 6 Ω r Turn-On Rise Time 8.5 17 ns td(off) Turn-Off Delay Time 11 20 ns tf Turn-Off Fall Time 3 10 ns Qg Total Gate Charge VDS = 10 V, ID = 1.7 A, 3.5 5 nC Q VGS = 4.5 V, gs Gate-Source Charge 0.55 nC Qgd Gate-Drain Charge 0.95 nC
Drain-Source Diode Characteristics and Maximum Ratings
IS Maximum Continuous Drain-Source Diode Forward Current 0.42 A VSD Drain-Source Diode Forward VGS = 0 V, IS = 0.42 A (Note 2) 0.7 1.2 V Voltage
Notes: 1:
Rθ is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal reference is defined as the solder mounting JA surface of the drain pins. Rθ is guaranteed by design while R is determined by the user's board design. JC θCA a) 250°C/W when b) 270°C/W when mounted mounted on a 0.02 in2 on a minimum pad. Pad of 2 oz. Cu. Scale 1 : 1 on letter size paper
2:
Pulse Test: Pulse Width ≤ 300 µs, Duty Cycle ≤ 2.0% www.onsemi.com 2
