Datasheet MAX4626, MAX4627, MAX4628 (Maxim) - 7
ManufacturerMaxim
Description0.5Ω, Low-Voltage, Single-Supply SPST Analog Switches
Pages / Page9 / 7 — Test Circuits/Timing Diagrams. MAX4626. MAX4627. MAX4628
File Format / SizePDF / 691 Kb
Test Circuits/Timing Diagrams MAX4626 MAX4627 MAX4628
MAX4626/MAX4627/ 0.5Ω, Low-Voltage, Single-Supply MAX4628 SPST Analog Switches
V+ tr < 5ns
MAX4628
V t INH f < 5ns LOGIC V+ INPUT 50% NO COM V V INL N_ VOUT OR NC R t L OFF CL 50Ω 35pF VOUT IN 0.9 · VOUT 0.9 · VOUT SWITCH 0V GND OUTPUT tON CL INCLUDES FIXTURE AND STRAY CAPACITANCE. LOGIC INPUT WAVEFORMS INVERTED FOR SWITCHES RL THAT HAVE THE OPPOSITE LOGIC SENSE. VOUT = VN_ R ( ) L + RON Figure 2. Switching Time
MAX4626 MAX4627
V+
MAX4628
∆VOUT R V+ GEN V NO COM INH VOUT OR NC IN C V L OFF OFF GEN ON GND IN ON OFF OFF IN V Q = (∆V INL to VINH OUT)(CL) IN DEPENDS ON SWITCH CONFIGURATION; INPUT POLARITY DETERMINED BY SENSE OF SWITCH. Figure 3. Charge Injection +5V 10nF OFF-ISOLATION = 20log VOUT NETWORK VIN ANALYZER V+ 50Ω 50Ω 0V OR V+ IN VIN ON-LOSS = 20log VOUT COM VIN 50Ω USE
MAX4626
ONLY FOR
MAX4627
ISOLATION
MAX4628
VOUT MEAS REF NO GND 50Ω 50Ω MEASUREMENTS ARE STANDARDIZED AGAINST SHORTS AT IC TERMINALS. OFF-ISOLATION IS MEASURED BETWEEN COM_ AND “OFF” NO_ OR NC_ TERMINAL ON EACH SWITCH. ON-LOSS IS MEASURED BETWEEN COM_ AND “ON” NO_ OR NC_ TERMINAL ON EACH SWITCH. SIGNAL DIRECTION THROUGH SWITCH IS REVERSED; WORST VALUES ARE RECORDED. Figure 4. On-Loss and Off-Isolation www.maximintegrated.com Maxim Integrated │ 7
