Datasheet MURS140, MURS160 (Diodes)
Manufacturer | Diodes |
Description | Super Fast Rectifier |
Pages / Page | 5 / 1 — MURS140 - MURS160. Green. 1.0A SURFACE MOUNT SUPER-FAST RECTIFIER. … |
File Format / Size | PDF / 197 Kb |
MURS140 - MURS160. Green. 1.0A SURFACE MOUNT SUPER-FAST RECTIFIER. Features. Mechanical Data
MURS140 - MURS160 Green 1.0A SURFACE MOUNT SUPER-FAST RECTIFIER Features Mechanical Data
• Glass Passivated Die Construction • Case: SMB • Super-Fast Recovery Time For High Efficiency • Case Material: Molded Plastic. UL Flammability Classification • Surge Overload Rating to 35A Peak Rating 94V-0 • Ideally Suited for Automated Assembly • Moisture Sensitivity: Level 1 per J-STD-020 •
Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
• Terminals: Matte Tin Finish (Lead Free Plating). Solder Plated •
Halogen and Antimony Free. “Green” Device (Notes 3 & 4)
Terminal - Solderable per MIL-STD-202, Method 208 • Polarity: Cathode Band or Cathode Notch • Weight: 0.093 grams (approximate) SMB Top View Bottom View
Ordering Information
(Note 5)
Part Number Case Packaging
MURS140-13-F SMB 3000/Tape & Reel MURS160-13-F SMB 3000/Tape & Reel Notes: 1. EU Directive 2002/95/EC (RoHS) & 2011/65/EU (RoHS 2) compliant. All applicable RoHS exemptions applied. 2. See http://www.diodes.com for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. Product manufactured with Date Code 0924 (week 24, 2009) and newer are built with Green Molding Compound. 5. For packaging details, go to our website at http://www.diodes.com.
Marking Information
U1xB = Product type marking code U1GB = MURS140
YWW
U1JB = MURS160 = Manufact urers’ code marking
U1xB
YWW = Date code marking Y = Last digit of year (ex: 2 for 2002) WW = Week code (01 to 53) MURS140 - MURS160 1 of 5 October 2012 Document number: DS30130 Rev. 11 - 2
www.diodes.com
© Diodes Incorporated
