Datasheet VERSA-PAC (Eaton)
ManufacturerEaton
DescriptionInductors and Transformers (Surface Mount)
Pages / Page9 / 1 — VERSA-PAC® Inductors and Transformers (Surface Mount). Applications. …
VERSA-PAC® Inductors and Transformers (Surface Mount). Applications. Product features. Environmental data
Datasheet VERSA-PAC Eaton
Technical Data 4301 Effective August 2017 Supersedes March 2007
VP VERSA-PAC® Inductors and Transformers (Surface Mount) Applications
• Inductors: buck, boost, coupled, choke, filter, resonant, noise filtering, differential, forward, common mode • Transformers: flyback, feed forward, push- pull, multiple output, inverter, step-up, step- down, gate drive, base drive, wide band, pulse, control, impedance, isolation, bridging, ringer, converter, autoAutomotive electronics (under hood, interior/exterior) • Telematics
Product features
• GPS • Six winding, surface mount devices that • LED Lighting offer more than 500 usable inductor or transformer configurations • LCD Display • High power density and low profile • Portable media devices • Low radiated noise and tightly coupled windings
Environmental data
• Power range from 1 Watt – 70 Watts • Frequency range to over 1 MHz • Storage temperature range (component): -55 °C to +125 °C • 500 Vac Isolation • Ferrite core material • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant
